Cold start idle problem!
Ever since I had my Trans Am tuned for the converter I started having problems with the idle air control. I have taken it to a shop to be fixed and now I am not getting any codes for the IAC but when the car is cold the RPM's surge up and down and will constantly stall out until they finally catch. Even then for the first few minutes will driving it will stall out once or twice. When the car is warm it really doesnt do it, but if it has been sitting for more than an hr or so it will. I do not really drive the car all that much but no matter how many times I take this to get fixed I am having the same problem, does anybody know what may be causing this? Does this need a re-tune? I never had this problem before the converter.
thanks for any help!
![Suspicious](https://ls1tech.com/forums/images/smilies2/suspicious.gif)
yes it has a comp cam with 566, 568 lift at 222/224 duration and the converter is a FTI 3600. Upon initial startup the car blows black smoke and the wall where the *** end meets the garage is covered in black. I was told that they tend to fire up a little rich when they are cold, is this true?
Im not sure who said that was ok but it sounds like you may need to find a new tuner.
I am installing a new suspension this weekend and I am going to pull the plugs and replace them since the car has had a few crappy tunes and the plugs have never been changed. It cant hurt and for what it is going to cost it will be cheap insurance, all i have to do is find someone somewhat local who can tune it.
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Cam like that makes an over-estimated air mass at low
RPM. That overfuels the motor to begin with.
The elevated idle MAP when cold, indexes you into a
higher open loop enrichment. Compounded by airflow
errors.
Overfueled means the motor is slow to respond to IAC
air changes so the RPM control loop becomes unstable
and over / undershoots.
Getting the low end airflow metering right is job 1, and
then shave back on the EQ vs ECT vs MAP table to
get a lesser enrichment (once you have the basic facts
straight, air-wise).
errors.
errors.
errors.
