Where to align rear suspension
Anyone know a place that would set up all the suspension in the car? I just went through another tail shaft housing (first one was over tightened and cracked). I thought when I purchased and had all this installed it was aligned. Guess not, the tailshaft housing and a nice crack in it from all the pressure being on it. Couple hundred dollars later and the part on the way I really dont want to go through this again. Anyone know who can set up or align whatever the correct term is all the rear suspension on the car in S. Fl?
Their is no way to change anything on the back of these cars unless you have installed after market torque arm and lca.Even if some how you have beant something the u joints would give enough play to where it would not break the tranny.Are you sure its the corrrect drive shaft and your not ramming it into the tranny when the suspension is compressed?
