New to Central Florida - seeking shop advice
Hi. I'm new in Florida (job move, etc), and my old 98 Z28 (180k+ miles), mostly original car (it's been a really good driver), needs some serious work (someone put synthetic dextron into my Tremec, and we know what that's led to...). Wondering if anybody has any recommendations for shops in Florida (anywhere from PCB, to Jacksonville, to Tampa, or beyond), that really know these cars? Any recommendations welcomed.
Thanks, Bob.
Thanks, Bob.
If it's a simple transmission rebuild there are various shops. If you're looking for more work geared towards the LS engine there are also a few here and there. Depends on what you're looking for. I'm central, FL, too.
Just FYI, I'm just outside of Gainesville.
I'll admit I'm a little envious of those with the skill and determination to do all their own work, but even so a transmission is more than I'd ever think to do all by myself. Although, my dream house, not that it will ever happen, would have a big garage building, a lift, and space just for projects. I have not so fond memories of working in a tight townhouse garage, taking half the dashboard apart, to change the heater core out of an '88 Camaro, in the winter. And I was young then....
A rebuild kit isn't that expensive but the labor to pull the transmission, rebuild the transmission, put it back in, is not cheap. I would suspect you'll be into it for probably close to $3k. A new transmission is about $2,200, after core charge. Then you're out the labor so probably a little more expensive. The good thing is the warranty on a new transmission but some shops will warranty their work. I haven't done a transmission swap in a few years but I don't remember it being of the utmost difficulty. On jack stands would suck, a lot, but it can be done. Last one I did on jack stands was a 70's Camaro. I'm not that daring anymore. Creeped under with it on my chest. Haha
I'd first set a budget, include everything imaginable, and go from there. Not sure what shape your clutch is in either.
My last T56 rebuild (2007?) was done by Lamotta Performance, in Longwood FL. That is a NE suburb of Orlando and they've always had an excellent local reputation for Tremec & Borg Warner rebuilds. There are other local shops that claim to be competent, but based upon my experience with Lamotta, I'd wait to use them if I had the option. Without digging out my receipt, I seem to recall it was $250 to R&R the tranny, $250 in labor to rebuild the T56, plus any needed parts... but again, that was probably around the year 2007.
AGREED.
Just took my 10 year old forged motor apart because it had a little issue. Lashway installed this when it was brand new 10 years ago. I gave them all my parts from my old motor (big 436ci stroker) and they were to install all my old parts and than install the new forged engine in my car.
They took my 80 LB after market injectors and gave me some used factory AC Delco injectors. Just seeing this now because I'm tearing everything down again.
Great.
Great.
