Florida Members Fun, sun and LS1's
headers installed, but!
Old May 19, 2007 | 06:34 PM
ssfugazi's Avatar
Default headers installed, but!
Finished my header and y pipe install in 7 hours, but I ran into 2 problems.
I need an EGR deleting kit and an o2 extention. They sell them on ebay, but I don't want to wait that long. Does anyone know where I can get them
ASAP?
Old May 19, 2007 | 06:36 PM
Rob@EFIAlchemy's Avatar
LS1Tech Sponsor
just plug in your rear o2 and zip tie them up under the car till you get them tuned out it wont throw any codes and go to like home depot and by some sheet metal cut it to fit and the bolt the old egr end to it just cut off the hose
Old May 19, 2007 | 07:21 PM
FASTERthanYOU's Avatar
I bought a fuel pump block off plate for a SBC at nappa, the holes where perfect, just had to cut off a peace that over hanged and and would have hit the block, it wasn't prity, but it worked great.
Old May 19, 2007 | 07:33 PM
ssfugazi's Avatar
I have the rear o2s taken care of. It's the front driver side o2 that I can't plug in.
How do I plug up the hole in the intake where the egr pluged in?
Old May 19, 2007 | 08:00 PM
hpmotorsports's Avatar
38mm freeze plug
Old May 19, 2007 | 08:29 PM
Razor_Blade's Avatar
What kind of plug do you need on the O2 extension? I have a 24'' four wire extension with a flat connector new in the box, that I won't be using for a few days.
If it's an emergency, you could allways extend it yourself. Just make sure you solder and heat shrink the splices. Worst case is you would have to by a new O2 sensor if it didn't work out well.
The egr stuff should be pretty easy to make. I used an old aluminum road sign to make mine.
Old May 19, 2007 | 08:33 PM
rss0694's Avatar
Default Aftermath Performance
If you want to call me tomorrow at the shop. Aftermath Performance in Ft. Myers i will check if I have any. I should be there after 11am. The # is 239-939-4649. My name is Roy and I hope I can help.
Old May 19, 2007 | 09:54 PM
ssfugazi's Avatar
That's exactly what I need.
Old May 19, 2007 | 09:55 PM
ssfugazi's Avatar
I'll give you a call tomarrow. Thanks
Old May 20, 2007 | 06:21 AM
I'm in Oviedo. It's probably a couple of hours from you, but you can come get it, if that's your best option. I just paid $55 to have a pair of them delivered, so you can have one for $28. I have plenty of time to order another one. You can call me at 407-304-6261, and get the address. I'll be close to home all day.
