Who's making 700+RWHP on 346/347ci w/Blowers
But not only is a chassis dyno measuring engine power, but its also indirectly measuring drivetrain efficiency. For example, I have a light converter, aluminum flex plate, very efficient converter, aluminum direct drum, lightened reaction carrier, fairly light dirveshaft, lightened spool, lightened and anti-friction coated ring and pinion, lightened axles etc. So even someone else with a regular TH400 and standard 9" with a heavy posi and a junk torque converter may be looking at 600rwhp with the same flywheel horsepower as I make.
It just depends where you want to spend the money, a badass 4L80 conversion costs way more than I had in everything I had from the flywheel back..
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I'm just trying to get an idea what it takes to hit that 700 mark in terms of cubic inch and boost with a blower. I don't want to run 18+psi of boost regardless of cubic inch to get there. Thats just me. If I have to up the cubic inch with less boost to get there, then that is what I have to do, but then its how much more. If I don't have to up the cubic inch the more my pocket book likes me.
Yes I am well aware of this.
346, 347ci, 700, 901, compression, d1sc, efficiency, f1a, limitation, ls1tech, power, procharger, py3400, rwhp, yank
