More Problems!!!
And Yes it has a 3 bar tune on it for those that will ask!
I thought I traded with a pretty respectable FI guy here and until I talk to him I will Not mention any names. Car will not run at all with the 3 bar sensor plugged in. It starts for half a second and dies. No chance of it even running. So I turned up the fuel pressure to see if that helped nope. Got t up to 75 and nothing new.
Then I decided to plug in the 1 bar map to see if it would start. Much to my amazement the car started the first time. DId not run well by any means, so I turned down the fuel pressure the more I turned it down the better it ran was down to 9psi before it ran ok.
So in summary, map I got was bad now I do not even have a 2 bar map. I just want to try and finish this thing. Everyone that says that these projects will nickle and dime you..... Pfff they are not exaggerating.
So does anyone have a working 3 bar that they want to get rid of.
Thanks very much, and I apologize I probably should have mentioned that. Speed inc did put a 3 bar tune on it already, I had a 2 bar map on it and it was not running well obviously.
I am going to check some values tomorrow with autotap and see if I can come up with anything but as of right now I have been told that this sensor absolutely worked. So tomorrow we will see what happens
Tomorrow we will get some readings and if my sensor is bad I will send his back. The fact that his car runs with the 1bar makes me wonder about the 3bar tune. Hopefully we will get you going ASAP!!!! The Best V8 Stories One Small Block at Time
Question would be why would giving less fuel make it run. I was having a conversation with cablebandit and he made a very valid point to me. Why would less fuel make it run better, as you change sensors and go up (1 bar to 2 bar and then to 3 bar) should you not have to add fuel or is this not correct!
https://ls1tech.com/forums/pcm-diagnostics-tuning/1010285-1bar-map-3-bar-tune-experts.html
