My KYTP build
Old Nov 15, 2008 | 06:55 PM
  #41
Sluggish's Avatar
Bingo, I will have to check when the pipe comes back. I really hope it still clear, but I doubt it will. I was talking with another friend who was going to weld up the exhaust. Rerouting it around the bar and maybe going up to a 3.5" dp. I will see how much room I have tomorrow when we put motor in.
Old Nov 15, 2008 | 06:58 PM
  #42
trans2000am's Avatar
let me see if i can get a pic of my downpipe im sure its pretty much the same design but im still on factory kmember,that one reason i did the drain in the front timing cover also a little easier to get to if i have to remove it
Old Nov 15, 2008 | 07:06 PM
  #43
98Camarod's Avatar
Plug it and re tap it on the other side or in the front. Just get that out of the way so you will still have drainage.
Old Nov 15, 2008 | 07:15 PM
  #44
http://s412.photobucket.com/albums/p...1226798061.jpg
here is a pic of my drain in the front cover
Old Nov 15, 2008 | 07:23 PM
  #45
Sluggish's Avatar
I thought of that, and may do it.
I wasn't sure if it would be low enough so plus I didn't have a picture at the time.
Old Nov 15, 2008 | 07:32 PM
  #46
im not sure how high your turbo is mounted but its enough for my st80
Old Nov 15, 2008 | 07:46 PM
  #47
Sluggish's Avatar
I don't know how long these things have been on the front steps.
Old Nov 15, 2008 | 07:50 PM
  #48
what kinda coating is on it?why white ?
Old Nov 15, 2008 | 07:54 PM
  #49
Sluggish's Avatar
Its aluminum just looks white in that light.
Old Nov 15, 2008 | 08:25 PM
  #50
WS6HUMMER's Avatar
I'm sure yall will figure it out, I have had to redo a few minor things myself, thats just how it goes when you are turbocharging a car that didnt come with a turbo.
Old Nov 15, 2008 | 11:02 PM
  #51
black01_WS6's Avatar
I love the simplicity of this turbo kit, I just wish you could keep the AC.
Old Nov 16, 2008 | 12:05 AM
  #52
Sluggish's Avatar
A/C would be a plus but since I rarely drive this car anyway I decided it wasn't a necessary. I drive with the windows down 90% of the time. But one thing I will not live without is a heater, Homey don't play that.
Old Nov 16, 2008 | 12:07 AM
  #53
Sluggish's Avatar
Looks good so far. You need to do some more work on the car and quit being a whispering eye
When I first read this I didn't get it, but I saw Roll Models last night and it all came together.
Old Nov 16, 2008 | 07:57 AM
  #54
98Camarod's Avatar
yea, I thought you said you seen it, so I'd figure I'd throw that in there. I'd rather have your kit then mine, I don't need a/c and I don't have it on, but my kit still keeps it. I'll trade you
Old Nov 16, 2008 | 08:48 AM
  #55
Big Bird WS6's Avatar
first i have read alot that is is bad to dump in front cover. having that hot oil dump on oil pump and timing chain.
is this true
second were you get coating at?
Old Nov 16, 2008 | 10:07 AM
  #56
Sluggish's Avatar
Place in Houston called Polymer Dynamics aka Polydyn.
Old Nov 16, 2008 | 02:01 PM
  #57
is this true
im not sure if its true but ive seen plenty of ppl do it. its no where close to the chain
Old Nov 16, 2008 | 08:31 PM
  #58
Sluggish's Avatar
Here is what happen today, sorry about the pictures the camera was on manual mode for some reason. First thing I did is relocate the the drain. I had oil all over me and everywhere else. Once I got the pan on I ran to get some exhaust manifold gaskets and an oil pressure sending unit. I got home put on the manifolds, coils and plug wires. The had to go back to the part store for some nuts and bolts. Seem like I wasted a lot of the day driving around.
So this build has been going pretty smoothly besides putting the drain in the wrong spot and then someone who will not be named broke my oil pressure sensor. Those were really not a big road block but here is my next issue.
As you can see that is a tight clearance, I have turbo turn as much as possible to get it off the pulley. The reason I believe it is so close is the pulley is not all the way on. It is not flush with the crank. I think that with since the timing chain is a double roller unit and thicker is the issue. They had to shim out the oil pump ( I had to grind the cover for it to fit). I could gain an 1/8th maybe a little more if the pulley could go on farther.
Now I have two ideas to fix this problem.
1: Remove the stock pulley and have it machined down to get back that 1/8".
2: Order a underdrive pulley and have plenty of clearance. This sounds like the better idea but there maybe another problem. With the smaller pulley the belt will be closer to the turbo.
I don't know if the belt will clear. What do you all think will be the better route?
Old Nov 16, 2008 | 08:47 PM
  #59
black98ws6ta's Avatar
I just now put 2 and 2 together. I replied in this thread earlier about the mellings oil pump. That pump is not designed to be used with a double roller chain. That would explain the complications. I believe the back side of the crank pulley is hitting the pump gear, if it is putting pressure on it, it will tear the pump up quickly. Either one of your options sounds like a good solution, personally I would stick with a stock diameter crank pulley.
Old Nov 16, 2008 | 09:24 PM
  #60
Broke EF's Avatar
Man you need help taking pics, but looks nice.
Sean
