My KYTP build
Old Dec 1, 2008 | 12:24 PM
  #121
black98ws6ta's Avatar
If the wideband is right, it looks like it could use some fuel.
Old Dec 1, 2008 | 12:43 PM
  #122
Sluggish's Avatar
Yea it jumps around, once it its boost it goes 10.0 then it starts leaning out around 5500 it goes 12.2ish. So more fuel is a must or turn the boost down a pound.
Old Dec 1, 2008 | 01:09 PM
  #123
RealQuick's Avatar
Based on that video, you hit 15.0 A/F twice when in boost. I'd pay attention to that and get some more fuel in.
Old Dec 2, 2008 | 07:40 AM
  #124
smokinHawk's Avatar
good to see you get it running.
what fuel rails are those, and why are you missing a bolt on the alternator?
Old Dec 2, 2008 | 11:09 AM
  #125
Sluggish's Avatar
Those weren't WOT, we drove around last night for about 2 hours. Theblur got the part throttle/driveability almost dialed in, +- 1-3% fuel trims in most cells. We will be working on the PE tables soon.
Those came with the with the PP typhoon intake I used to have. They are basically Speed inc. budget rails. I have had hell finding a bolt, are local mom and pop store that has ever bolt known to man is closes right now trying to recover from the hurricane damage.
Old Dec 2, 2008 | 12:15 PM
  #126
RealQuick's Avatar
I hear ya, but even at part throttle, it looks like you had positive manifold pressure. You don't need to be WOT to be in boost As long as you are comfortable with it... just wanted to point it out.
Old Dec 18, 2008 | 08:52 AM
  #127
B18CYA's Avatar
Very nice build love the big d_ck cam. Just wondering if you had to cut up your bumper cover at all to fit the i/c?
Old Dec 18, 2008 | 03:12 PM
  #128
Sluggish's Avatar
Just a little, where it went up in front of the radiator. It's nothing you can see. I also trimmed the plastic vents that are on bottom of the bumper. I used some of the medical scissors that EMTs carry.
Old Dec 21, 2008 | 12:39 AM
  #129
Sluggish's Avatar
I had to pull the intake off today to fix an oil leak from the oil pressure sending unit. Since I had it off I decided to take care of the MAP sensor while I had the chance. I hasn't popped out yet but it takes very little effort to remove. I am sure it would pop out on its own when the boost gets turned up. I also lift the car back up to where it's level.
It took maybe 10 minutes.
3/8" NPT tap
19/32" drill bit
3/8" NPT x 1/4" barbed fitting
1/4" vacuum hose
I think this should hold up well.
Old Jan 2, 2009 | 01:09 AM
  #130
blazin's Avatar
Did you have to remake the PS lines, or were you able to get them bent outta the way?
Old Jan 2, 2009 | 10:33 AM
  #131
Sluggish's Avatar
Just bent them.
Old Jan 2, 2009 | 06:53 PM
  #132
TheBlurLS1's Avatar
That's what she said...
We also just bypassed the PS cooler by re-routing one of the stock lines. That bought us some more room.
Old Jan 2, 2009 | 06:58 PM
  #133
blazin's Avatar
Any pics of this im sure u just connect the two that were on the coolant hose?
Old Jan 3, 2009 | 10:54 AM
  #134
blazin's Avatar
What kinda INJ duty are you getting with the 42lbers?
Old Jan 3, 2009 | 11:23 AM
  #135
Sluggish's Avatar
About 90%, my fuel pressure is dropping down to 50psi which is why its so high.
I don't have any pictures of the hose. Do you even have a PS cooler. If you do just take the clamps and hose off of it. Bend the hose back around to the other nipple on the pump. Trim it so it is short as possible.
Old Jan 3, 2009 | 11:54 AM
  #136
blazin's Avatar
Thanks for the info. You got any updated vids
Old Jan 3, 2009 | 03:48 PM
  #137
Sluggish's Avatar
No but I need to get some. I have been waiting on my meth kit to come in.
Old Jan 18, 2009 | 01:03 PM
  #138
Sluggish's Avatar
After looking around and seeing how people cut there grills out I decided to do mine.
It looked like **** red so I cleaned up the cuts and painted what was left of the grill. I left that much for support of the bumper.
Old Jan 18, 2009 | 01:17 PM
  #139
Sluggish's Avatar
Also my Snow kit came in and I got it installed. It was a very easy install and allowed me to turn the car up from 7 to 12 psi which really woke it up. The car feels a lot faster than it ever has. I am ready to go to the track and see what kind of trap speeds it can lay down. I am guessing 12# would be close to 700rwhp. I will have to wait to get on a dyno to find out.
Old Jan 18, 2009 | 03:44 PM
  #140
blazin's Avatar
I cant wait to see some vids lol.
