My KYTP build
Old Apr 12, 2009 | 07:58 PM
  #161
Silver_TransAm's Avatar
Glad I could help . Now lets see a 9sec pass !
Old Apr 12, 2009 | 09:48 PM
  #162
mairen25's Avatar
pretty nice,that's the reason why im waiting for josh.enjoy it.
did you buy only the pipes to josh,or everything.how much.
Old Apr 12, 2009 | 09:59 PM
  #163
98Z28CobraKiller's Avatar
Restricted User
Those wheels would look way better on my car. LOL.
Very nice!!
Old Apr 13, 2009 | 12:00 AM
  #164
z28adiction's Avatar
love the stance of the car its perfect! Hope mine has the same when done.
Old Apr 13, 2009 | 01:34 AM
  #165
Nacho SS's Avatar
Great build...I've read all 9 pages and its inspiring...good work!
Old Apr 13, 2009 | 05:42 AM
  #166
Sluggish's Avatar
I bought everything but the turbo, it was like $3600 at the time.
Thanks for the comments guys.
Old May 11, 2009 | 03:29 PM
  #167
Vetal's Avatar
Originally Posted by Sluggish
Smokinhawk alternator relocation bracket + 25% UD pulley = 71.5" belt. You have to take the left bolt out and roll the alternator over towards the intake. Force the belt on and roll it back then stab the bolt. The belt fits great and doesn't slip at all.
Are there any additional tensioners? Looks like that stock tensioner isn't doing anything useful...
Old May 27, 2009 | 07:55 PM
  #168
Vetal's Avatar
Sluggish, it looks like you didn't move stock radiator at all?
Old May 27, 2009 | 08:17 PM
  #169
Sluggish's Avatar
I didn't, It is pushed forward at the bottom a little that is it.
The stock tensioner is just barely doing its job but the belt is pretty tight and it doesn't slip at all.
Old May 27, 2009 | 08:30 PM
  #170
Vetal's Avatar
That's weird how you managed to squeeze stock radiator in stock location with that turbo
Also, turbo sits pretty low, don't you have problems with oil drain? Do you have a pic of drain pipe?
Old May 27, 2009 | 09:31 PM
  #171
Sluggish's Avatar
There is plenty of room like 3-4 inches, the turbo isn't that big. The turbo is above the pan, I can get a picture of the drain tomorrow if you want.
Old May 28, 2009 | 03:32 AM
  #172
98Camarod's Avatar
Here is what happen today, sorry about the pictures the camera was on manual mode for some reason. First thing I did is relocate the the drain. I had oil all over me and everywhere else. Once I got the pan on I ran to get some exhaust manifold gaskets and an oil pressure sending unit. I got home put on the manifolds, coils and plug wires. The had to go back to the part store for some nuts and bolts. Seem like I wasted a lot of the day driving around.
this is what you used right?
Old May 28, 2009 | 10:02 AM
  #173
Sluggish's Avatar
Yep, I have had no issues yet with it.
Old May 29, 2009 | 04:27 AM
  #174
Vetal's Avatar
Do you run front stabiliser bar? I don't remember seeing it in the pics
Old May 29, 2009 | 02:04 PM
  #175
Sluggish's Avatar
No, I had ditched it long before doing the turbo install.
Old Aug 10, 2009 | 10:53 PM
  #176
wes96z's Avatar
Has there been any track updates on this since the install of the twin disc?
Old Aug 16, 2009 | 11:17 AM
  #177
Sluggish's Avatar
10.61 @ 131, having an issue with either valve float or boost leak. That was with 42lb injectors and one fuel pump. I have 60lbers now and am in the process of adding the 2nd pump. I'm leaning towards a leak now since I pulled a head off and had it checked out. I think a low 10 will be easy and maybe even a very high 9.
Old Aug 27, 2009 | 09:21 PM
  #178
waterbug1999's Avatar
Nice build... You ever get it on the dyno?
Old Aug 28, 2009 | 07:46 AM
  #179
Sluggish's Avatar
Only once. It made 530rwhp on a mustang dyno with the boost set the same as the 10.6 pass. It would peak at 12lbs then bleed down 11 or 10lbs. I'm still trying to get the bugs out of this thing.
Old Sep 4, 2009 | 03:06 PM
  #180
99Ls1fever's Avatar
Just An Amazing Build.
I am thinking about doing this kit on my WS6. Finally got done with My Z28 Build and now moving on and have been very interested in kentucky turbo builds.
How much did the turbo kit itself cost you with all of the upgrades and parts you needed and added?
Also what were your final power numbers with this kit and the boost you were running?
Thanks Man, Amazing Job and an Amazing Ride!!!
