Open Down Pipes Bad???
Old Nov 10, 2008 | 12:16 AM
1999ssls1's Avatar
Question Open Down Pipes Bad???
I have an Incon TT kit and have open down pipes right now. The pipes run about a foot from the turbos. Will this hurt anything? I like the way it sounds and Im sure it helps performance aswell.
Thanks
Old Nov 10, 2008 | 12:17 AM
67Firebird455's Avatar
That's how I ran my rear mount and I never had any problem!
Old Nov 10, 2008 | 12:22 AM
myfast70's Avatar
It shouldn't be a bad thing. The turbo may spool a bit quicker since it is shorter. On the GN's, guys with open down pipes have them about 4-5 feet long. I think as a rule (and I can be wrong) that the exhaust outlet has to extend past the flywheel to be NHRA legal.
Old Nov 10, 2008 | 12:57 AM
black98ws6ta's Avatar
Nothing wrong with it.
Old Nov 10, 2008 | 05:31 AM
cablebandit's Avatar
on the incons you can hear the turbos whistle when you let off the gas with open downpipes
Old Nov 10, 2008 | 08:17 AM
1999ssls1's Avatar
I got it running the other night and it sounds awesome! I like the whistle. I just didnt want to burn anything up.
Old Nov 10, 2008 | 09:45 AM
Adam Connell's Avatar
The reason why your supposed to have "X" feet of exhaust on N/A engines is so that your dont burn the valves up from lack of back pressure... since you got two turbos at the end of your manifolds creating back pressure you are good to go! I ran my GN open down pipe for a year before I got tired of it!
On my buddies whipple mustang we saw 22rwhp on the dyno from uncapping his dumps at the headers. Forced induction loves open exhaust!
Old Nov 10, 2008 | 10:27 AM
1999ssls1's Avatar
Thanks guys!
Old Nov 10, 2008 | 04:08 PM
cbr600rx7's Avatar
I could be wrong but dont you need a little back pressure on a turbo to help prevent turbo surge?
Old Nov 10, 2008 | 04:09 PM
Not at all, the less restriction after the turbo the better.
Old Nov 10, 2008 | 04:10 PM
casey38boost's Avatar
I used to run an open downpipe on a 89 turbo trans am for years with no problems, just turbo noise.
I don't think u would run into a problem with an open dump. plus u will get quicker spoolup and possibly an increase in boost, keep an eye on it.
Old Nov 10, 2008 | 10:54 PM
handoverthebong's Avatar
don't quote me on this, but isn't surge whenever you let off the gas, and as the turbo forces air into the manifold, but the throttle body is closed? i'm a NA guy, but just my .02
Oh and hey everyone, first post here, i popped on over from ls1gto.com
Old Nov 10, 2008 | 11:34 PM
That's what a blow off valve is for, that can backspin the turbo obviously causing damage. Handoverthebong - Glad you made it over this way! =)
Old Nov 11, 2008 | 02:47 AM
cbr600rx7's Avatar
I stand corrected
Old Nov 11, 2008 | 05:13 AM
lifeisgood's Avatar
ill be running an odp. plenty of people have and no worries
Old Nov 11, 2008 | 06:35 AM
ayousef's Avatar
im thinking of going the same, just a straigh-through pipe after the turbos, but I am wondering how loud the sound of that thing would be. I know single turbos tend to do a better job at contolling the sound level, but with small twins, I might need a muffler, or Ill have to work out a custom exhaust to utilize the stock butterflies to work.
Old Nov 11, 2008 | 07:19 AM
Broke EF's Avatar
Two potential problems we have had that may or may not be to the open down pipe.
1. We think the down pipe is making the knock sensors read false knock
2. We think the down pipe being so short is burning out the wide band faster
Our down pipe is all of 8" or so and dumps in front of the cross member. Reason for the thought on number 1 is when tuning it was picking up knock even with a VERY conservative tune up and low boost (2-3 psi). Thought gas was the issue so we drained the tank and tried again, same problem. Checked the brand new plugs, nothing wrong there, so we concluded that it COULD be the issue. Reason for number two is the wide band is only about t2 inches from the end of the pipe. Couple that with it being a 4" pipe when you get off the throttle air is bound to go back onto the sensor. We built an exhaust for the car, that's why the sensor is so far down the down pipe, but had clearance issues so never put it on. Other than our not so common problems (that may or may not be from the short open down pipe) there really is no negatives. Its not as loud as you would think either when driving normal.
Sean
Old Nov 11, 2008 | 07:37 AM
ayousef's Avatar
Sean
Single turbo or twins?
Old Nov 11, 2008 | 08:17 AM
Broke EF's Avatar
Single precision GT42-76
Sean
Old Feb 4, 2009 | 07:28 AM
crashly's Avatar
nope, mine sound nice....
