Patriot Dual Spring Failure
Old 11-18-2008, 12:26 AM
rx_treme's Avatar
Default Patriot Dual Spring Failure
I had my car tuned a while back (>1000 miles) and drove great since then. Then after a drive I was having major stumbling issues trying to get into boost and overly rich conditions all of a sudden (more or less) but it drove just fine in vacuum. Started troubleshooting and I ended up checking FPR, Injectors (cleaned), new fuel filter, spark plugs, checked coils/wires. Still nothing but i could hear a slight tick more than normal valvetrain noise and predominately from the driver bank. so i decided to dig deeper and pull the valve covers.
Cylinder 7 Intake outer valve spring snapped and spun inside of its self (to where it can spin by hand). Inner spring looks ok though. That pushrod (Thunder Hardened) is just ever so slightly bent too, just barely enough to see a sliver of light (probably around 4-6 Thou). I pulled that plug and it looked fine. Looked inside of the spark plug hole and looks fine just a bit black/rich but obviously can only see so much.
The rest of the springs look ok too.
Well any ideas what could cause this or damage it could have done?
Can i just throw another replacement spring into it?
Old 11-18-2008, 12:32 AM
black98ws6ta's Avatar
How many miles on the springs and what camshaft?
Old 11-18-2008, 12:41 AM
rx_treme's Avatar
Not sure on mileage since I bought the heads used (supposedly low mileage) but i've only put less than 1600 miles on them.
cam is Custom CamMotion 223/219 .577/.566 116lsa
Could this be from oil not being hot and beating on it?
Just was thinking about the fact that since i have the oil cooler now (and its cold out) it takes twice as long for my oil temps to get to 180*.
but i always let it get some heat into it first.
Old 11-18-2008, 01:08 AM
IMO, I would have a hard time replacing just the failed one(s), I would just put a new set in.
Old 11-18-2008, 04:46 AM
EPP
EPP's Avatar
I agree, I'd put a whole new set it. This is a good example of how dual springs can save an engine from serious damage. Bob
Old 11-18-2008, 06:38 AM
LS1Tech Sponsor
hellbents10's Avatar
Yes replace the whole set!
Old 11-18-2008, 08:12 AM
mike13's Avatar
Every so often you hear about springs failing or spring related failures, it has changed my thinking. If I ever buy a set of used heads I'll throw a set of springs on no matter the mileage, cheap insurance.
Old 11-18-2008, 09:10 AM
rx_treme's Avatar
Thanks guys!
After thinking about it some, i believe the spring cracking was the initial failure. after it cracked and spun up into its self that caused it to coil bind which bent the pushrod.
I'm going to scope it next week to check the piston and head out.
Old 11-18-2008, 09:11 AM
the_merv's Avatar
Dual Springs save your ***..there is proof right there..
Old 11-18-2008, 11:06 AM
67Firebird455's Avatar
Eeesh man, I'm glad you had dual springs! I had that happen with a set of doug herbert springs when I was running a solid roller in my pontiac 455. Broke 4 of them and the thing still ran!
Old 11-18-2008, 11:24 AM
rx_treme's Avatar
anyone come up with a possible cause?
Old 11-18-2008, 11:27 AM
Did you beat on it when it was cold? I think that's why mine grenaded.
Old 11-18-2008, 11:51 AM
Gingervitis Addict
slow67's Avatar
Give Gunnar at Patriot a call. He can set you up with a new set of just springs (since you already have locks and retainers)
Old 11-18-2008, 01:27 PM
rx_treme's Avatar
Talked to Gunnar and he said its really rare that an outer spring breaks. Must have been too cold when i dropped the hammer.
Old 11-18-2008, 01:32 PM
Like I said, that's what happened to 4 of my solid-roller springs. Glad you caught it though, just be thankful you had double springs!
Old 11-18-2008, 01:48 PM
rx_treme's Avatar
Thanks for all the help guys,
what spring compressor do you guys normally use?
