mocal scavenger pump
Old Nov 18, 2008 | 03:02 AM
headed-ws6's Avatar
Default mocal scavenger pump
where can i find this pump?
Old Nov 18, 2008 | 07:36 AM
bboyferal's Avatar
Electric I'm assuming? Good question...
Old Nov 18, 2008 | 07:55 AM
mike13's Avatar
http://www.racerpartswholesale.com/p...al_Cooler_Pump
I just installed one of these on my system.
Old Nov 18, 2008 | 08:21 AM
OUTLAWZ RACING's Avatar
Good pump alittle loud but it works.
Old Nov 18, 2008 | 08:29 AM
mike13's Avatar
It's loud, I've only had mine for a couple of hundred miles, hoping the noise becomes a little smoother sounding. Right now it sounds a little gravelly.
Old Nov 18, 2008 | 03:16 PM
headed-ws6's Avatar
well is there a pump thats quieter but as good as the mocal?
Old Nov 18, 2008 | 04:53 PM
anarchy99's Avatar
When I replaced the scavenge pump in my incon kit from a tilton, I went to the mocal pump. I bought it on ebay new, can't remember the price, but it's worked great. It's a little loud, but it doesn't bother me.
Old Nov 18, 2008 | 05:50 PM
67Firebird455's Avatar
When I had mine, I had no problems with it, just loud as living hell.
Old Nov 18, 2008 | 06:49 PM
Sideways240sx's Avatar
What size drains you guys running? do you just do a 3/8 npt adapter to your -8 or -10 line. Id consider running a pump, but my drain is only about 8 inches, but the drain is only 3-4 inches higher then the turbo.
Chris
Old Nov 18, 2008 | 06:50 PM
I ran a -10an on mine, rear mount.
Old Nov 18, 2008 | 09:30 PM
headed-ws6's Avatar
when you say loud can you hear it while driving or when you out of the car?
Old Nov 18, 2008 | 10:31 PM
WestSide's Avatar
theyre loud when you have the key forward about to start the car, and if you have quiet exhaust. i was running open downpipe, dumping under the driver's seat with the pump in front of the radiator....and it didn't bother me a bit when the car was on. when i closed the cutout though, i could hear it easily especially while driving inside the cab, for some reason
Old Nov 18, 2008 | 10:57 PM
Silver_TransAm's Avatar
Oh man... I might need one. My stupid sts pump just went minutes ago. Luckily I caught a glimpse of all the smoke at a stop and pulled over. Get out and there is oil all over the back of my car. Good thing I was about a 1/4 mile from my place and just happened to have a couple of quarts of oil in the car. And yes I checked the fuse first. This damn kit has really pushed my buttons the last few days.
Old Nov 18, 2008 | 11:06 PM
mike13's Avatar
could be the relay, I ended up running a wire from the fuse box to the relay, sometimes the wire from the pcm wouldn't trigger the relay. I don't know if wasn't enough amperage but sometimes the pump wouldn't turn on and I would tap the relay and the pump would start up.
Old Nov 18, 2008 | 11:09 PM
I will check that as well before I throw in the towel. Thanks.
Old Nov 18, 2008 | 11:28 PM
pm sent
Old Nov 19, 2008 | 07:45 AM
bboyferal's Avatar
I run one from a brand called Hi-Flo... It has outlasted two motors and two turbos... Damned reliable.
Old Nov 19, 2008 | 03:10 PM
headed-ws6's Avatar
How quiet is the hi flo and where might I find it?
Old Nov 19, 2008 | 03:54 PM
Ping King's Avatar
got one for sale if you want
Old Nov 19, 2008 | 05:00 PM
headed-ws6's Avatar
which one do you have for sale?
