ATTN: Warbird....Please Reply Regarding Overheating Issue
Mike
Lastly, just to address the things you stated:
2\ My car runs hot - Band-aid fix - replace rad with SLP unit also add Tow Cool to rad - Result, car is cooler but still gets hot
3\ My car runs hot - Band-aid fix - replace passenger manifold with Mac Header - Result, car drops 15* under normal running, picks up 60 HP, however car still get hot under heavy load (this is important)
4\ Too much back pressure - Fix- Replace BB Triflow with Magnaflow install cut-out - Result, under normal driving car has finally dropped to 190* normal, car picked up 4 mph and 4\10 ths in the quarter
5\ Exhaust cross-over blew off -Band-aid fix weld middle split re-install wrap tube into manifold with header wrap and re-seal. Result - no more leaks in the cross-over
6\ Log manifold beginning to crack at number 3 port - Not fixed yet, another exhaust leak, nice ticking noise
7\ Recently dicovered more cracks in the manifold - This is where it became obvious where the heat generation and overheating was actually coming from.
The cross-over needs to be a minimum of 3" into a 3" log, the "headerlets" from the drivers side manifold need to be canted forward.
My last dyno was 573rwhp with the stock rad and fans. I think the problem is the iron block (if that's what you have) and not Robs kit. My guess is you need to look elsewhere for your overheating problem. Maybe you got a headgasket flipped wrong...happened to my dumba$$
Rob, how many of your kits are on big cubic inch daily drivers? I think he has made some valid points here relative to big engines and your system.
-Geoff
Have any other customers cracked the turbo manifold? Were they overheating as well or is it just from repeated heat cycling?
Also what would you suggest as a rad replacement? Is there a Becool rad or something similar that is roughly the stock rad's dimensions but cools to 800hp?
BTW Pauls car is an aluminum block not iron guys.
I think a cam change and some tubing changes will make a big difference. I would also like to see Paul move the intercooler to the nose and away from the rad like Rob has in his shop car.
Cheers,
Chris
ps- Rob you know as well as I do that Pauls car would be a LOW 10 second car at over 130mph with a 400 and brake. He is making NO boost off the line and the car drops a bit of boost on all four shifts. Plus the best sixty is something like a 1.68 on ET streets at 3800 pounds. I wouldnt say its a turd
FWIW you need to keep the stock gap between the radiator and the front shroud otherwise the car can run hot all the time.
With my setup we have been seeing 167F engine temps after 25 minutes of idling.
Remember, only one misinformed, extremely poor tuner, and one victim of lousy mechanics have experienced trouble, but they seem to get all the press here. Of course, I'm leaving out one other individual, but he seems to be a result of exaggeration and poor mechanical ability. This still leaves a vast, VAST majority of kit owners that don't experience these problems.
C'Mon guys, grab a clue from the clue bag! These two guys couldn't spin a wrench or diagnose a failure to save their *******.
Paul CAN'T produce a real reason, he only spewed the same crap he did before his lackluster hired wrenches found the overheating issue. Someone hit it previously: Paul can't suck in his pride long enough to admit the schmoes he paid so handsomely are incompetent, and so he seems as well.
Go ahead... claim what you will, but the fact is that NO ONE but Paul and the mouseketeer are so poor at the hobby as to fail miserably and blame it on the supplier. I live it every day with DCX and their Viper. Ah, to be in my 20s again, and have the world so figured out... One day in their 40s they'll see the truth, if their pride allows.
Blind pride does not allow for intelligent change!
SC-
-Geoff
So how many kits are out there? Under thirty, then I think there is a problem. Under twenty, then I would call it a major problem. What exactly is the "majority" you are referring too?
-Geoff
If less than 7% of the customers have such a rotten time, I go along with an install problem being a distinct possibility. How in the world can 28 guys have a decent running FI setup and two fail so miserably? And if they aren't willing to conference with the vendor and manufacturer, then they don't want to solve the problem or set the record straight.Does the kit have issues? Could be. I can come up with problems in every bolt-on FI kit. As much as I love my ATI, it has issues.
You guys should buy a showroom car and leave it like it came. You do not have what it takes to stay in the FI game. I may have problems that leave me scratching my head, but you don't see me bashing ATI every time I have problems... I talk to the vendor, I talk to mechanics, I post on the forums and I beat my head against the wall
until I get it solved.There... I've said it.
(...blue, your tone is still over the top. Say what you feel, but don't insult people, please.)
-The cam you have should carry you to far higher power levels. IMO, you don't need anything bigger.
-3in crossover would be a step in the wrong direction.
-While your radiator 'may' be insufficient, from the problems you describe (overheating only under power, and exhaust manifold cracking), I would take a look at your ignition timing.
Ignition timing that is too low at WOT/Boost conditions will cause EGT to skyrocket, causing overheating and cracking of the manifold.
Just throwing some ideas out there
Any track times from your car yet?
How come I haven't seen any vids or slips from "the fastest car in Michigan" or whatever you said it was?
Until you put up some decent numbers or have something constructive to say STFU.
Paul's car is already second fastest on the list for a 6speed now.
Wait till the bigger injectors/pump, new tune and slicks are in. My guess is 10.5-10.6@133mph or better this fall at 3800 pounds raceweight.
Rob, I have no animosity towards you or your company whatsoever. I am trying to help a friend (Paul) out with his car's issues. I think the car has at least another 100-150RWHP in it and at least another half a second ET.
Chris
I think you are right on about installation. None of the kits that Rob installs have any problems. That seems to be a fact as far as I can tell.
-Geoff
I have offered to do whatever is necessary to fix the problem, take part in a conference call, drive half way to Canada to pick up Warbird's car, etc., etc. If that's not enough, I can do no more.
Chris - I feel as though you have done nothing but try to be helpful to both me and Paul. You have always reserved judgement and I thank you for that.
There are many others who have supported us and apparently some who didn't, but now do. I also thank those people.
Tim Eger here at our shop has been working EXTREMELY hard on a C5 Twin Turbo kit. It is almost ready to release in fact. However, none of us ever dreamed that releasing a turbo kit could have possibly been this frustrating or damaging to our business. We really anticipated a high level of support, but apparently that's just not possible to the degree we had hoped. I seriously doubt that after all I've had to go through, we will even bother.
Not that most people will care, but we have yet to make ONE PENNY on the turbo kits. Believe it or not, that is an absolute FACT. Which only adds to my hours upon hours of frustration.
It was so much easier when we just sold airlids...
I didn't realize that because I am a "business man" that I am not allowed to "speak my mind". Heaven forbid. This crap has been going on for months, and last week was the first time I have actually ever spoken my mind. I've held back long enough in my opinion. Sorry, that's just me.
1.) Warbird - You said you fixed your overheating problem. True or False?
Hint:
3.) Warbird - So EXACTLY what was the problem?
For the life of me, I STILL cannot find his answer to this question in ANY of his posts! But I have now read in THREE different threads that he has fixed it!
So, PLEASE JUST ANSWER THESE QUESTIONS! This thread could have otherwise been closed nearly 24 hours ago.
