ATTN: Warbird....Please Reply Regarding Overheating Issue
Rob, you nor anyone else dictates to the moderators when to lock a thread. That being said, you made this bed, unless someone else locks it, from my perspective, you will lie in it.
Finally, it is obvious to me Warbird is not being forthcoming about the original question. I'd want him to clear up his unfounded statement if it were me he had maligned. He would want that, too, if he were incorrectly accused. So far, all he has done has been to tap dance around the question... no straight-forward answer. That speaks volumes to me... and calls into question the credibility of any other statements made; particularly when there are other kits driving around with no significant issues.
This thread could have been only two posts long had Warbird been a Man and simply answered my question, or proved me wrong. That's obviously still not going to happen. Mainly because I think he now sees this thread as a haven for having others bash me while he sits back and laughs. Why else would he let it go 6 pages long without a REAL answer?
I don't care if this thread gets locked, deleted, or turned into a rotating banner.
This entire episode will without a doubt affect my willingness to respond publicly to Message Boards in the future. This is why you now see so many Vendors that do not. Believe me, it's a subject that ALWAYS comes up when we sponsors/advertisers get together at SEMA, PRI, etc.
Some will see that as a good thing that my posting will be limited. However, I can guarantee you that many will be robbed of the help and knowledge that could be given from our posts.
I have nothing more to say.
Yet another vendor who attempted to provide us with an LS1 product and regularly posted to answer guys' questions gets kicked in the teeth and decides it's not worth it.
Perhaps some of you are happy, now.
Rob is mad.
I'd be mad too.
MM went 11.3@126 (almost a 127), I think that's a ringing endorsement of the QMP if I ever saw one. MM you did not know what your ARE motor had for a long time so call a spade a spade.
RiceEtr you are like troll city... You just keep the flame burning in these threads.
Warbird, I"m sorry but you used our board to vent and grip and dump, and now you won't post the results. I got your PM, and I am not going to respond to it. We use the message board to make things work, we don't gripe on it and then not tell anyone what worked or did not work. If you talked to Rob for an hour is that not a good thing why not appreciate that?
I just see blame/cry/gripe/cry coming from MM/Warbird/RiceEtr. You got tuner kits for like 60-70% of normal price so you get NO love from me!!! I know what a tuner version of the kit costs, I wish I had gotten one!
Rob, you forgot to change your user name
, I have held back in the hopes that you would offer to fix the problem or at least start to listen to what people had to say instead of being bull headed about the whole thing. Awwwwwwwwww **** it!!!!!!!!!!!!!!!!You are not here to help, you are her to make money. Being a philanthrapist is the furthest thing from your mind so lets drop the bullshit. Even spending time on the phone with you was a waste of an hour, you didn't offer to help you simply bashed my motor and told me what I already knew "change my exhaust"
Your kit was designed with an inherent design flaw that you know about and simply decided to push the limits of, without informing your customers. You were told this long before you built the kit in the first place. You have not answered yet to the question, "tuner kit/full kit" as to how many big displacement motors this kit has gone into? The reason you ignore it, is because mine is the only one on the road today. You maxed out your 404 and that is why I believe you sold it, it simply wasn't capable of making more power with the design of this log style kit and you knew it.
I have been working to clarify my position and have been in contact with a number of turbo experts in the field. My approach to solving my overheating issue was wrong because with your kit it can't be fixed only masked with the mods I have done. Just to clarify, the motor, placement of the intercooler, new rad, timing have nothing to do with my problem. It's the QMP turbo kit. Your tuner kit is identical in every way to the retail kit, except I chose to provide my own injectors, plugs and tuning.
My engine pumps easilly 50% more gases than a stock displacement engine for starters. The cause of my overheating is your log style manifold and the back pressure it causes in my engine and others. The problem will eventually show up in smaller engines (as breakage), especially when people start to up the boost. On a stock motor with your turbo kit, if you measured internal exhaust pressure under load you would easilly see around 60 psi of back pressure, high and eventually damaging, on my motor I am seeing 90+ psi of back pressure easilly enough to blow off my crossover pipes, crack manifolds, blow off clamps and damage my turbo seals (this is the reason I am blowing oil heavilly).
The fact that I welded my seams was a huge mistake because now pressure has no where to go except back into the motor, and it will eventuall grenade. The simple fact that my motor is still alive is a testament to how well built it was from the start.
Simply put my engine moves far more exhaust than your kit is able to handle, my exhaust backs up under load and where does that exhaust go? Answer; the exhaust is rigid so it trys to find an opening and or it pumps it right back into the motor overheating it. My car does not overheat or even get warm under zero load because the exhaust is able to flow at a slower rate and escape via the normal route (turbo is not spooled). Under load (turbo spooled) it can't, that's why my exhaust and engine resonate under load and the heat builds up very quickly and I start to overheat.
To date everything I have done, passenger header, oil scavenging pump, radiator, better coolant have only helped to mask this far more serious problem. I do know how it will be fixed but I simply won't tell you except to say I will longer have a QMP kit in my car.
You wanted a straight answer there it is, black and white, no more hinting.
I hope you're in this for the short haul on making money with these kits because I certainly smell the same odor I did with Incon. I could give a flying **** what your responses will be, more bashing, more avoiding direct questions, I know it you know it and I will deal with it on my own. I'm done with your games.
Please return to your regularly scheduled discussion
Paul
Bruce
So, can someone PLEASE shut Warbird up?
I'm done with Warbird, MM, and RICE ETR. I'm glad that none of them have, or will have our kit anymore. I'll continue to PROVE what can be done with it on my own car, as I have been doing. Who's ranked #1 again?
My car now has a T-88 with a 2 1/2 log, and a 2 1/2" crossover, and a STOCK passenger manifold. It STILL does not run hot. EVER. I'll do my talking at the track.
I completely agree about the Moderators job of handling this. Thank you.
psj fwiw we did not get a "deal"... we just did not pay for what we did not get (injectors fuel pump/tuning etc.)
so you are saying if it runs bad, its my fault because its a 'tuner' kit and i "tuned' it wrong.. but if it runs good then the praise goes to qmp for making a great product? toally contradictory.
situations like ours WILL happen and come up again if qmp sits on the kit as-is.. and i will have to watch people get f'd because we the customer are not being righted.
i dont think having a company car be a mere .1 faster than an individual with a stock bottom end is something to brag about.
What i said was it was NOT restrictive enough to cause the manifold to crack... so in other words... if the catback was so restrictive, that it was more restrictive than your manifold, then he would have never made any boost.
Oh, and while were on the subject..... how about you tell everyone what "special" things had to be done to your engine from ARE to get it to seal..... how about sonic testing to find the beefiest heads.... then how about welding up the head's water ports.... you want to know why all that work had to be done while others on nitrous and FI can make more hp/tq without all that work? Reason being is your engine is seeing a tremendous amount of cylinder pressure for the power you make compared to the others due to that restrictive log.....Why aren't you cranking up the boost yet and making some more power? Still can't get that 88 to make boost?
MM's HG's were perfect.... i know because i helped pull the heads off....
i do wonder why i don't see people complain about the BASE kit so much.
Who buys a base kit? someone with a modified engine? NO someone with a stock/mostly stock engine...making around the stock HP levels.... right? Ok, so with a stock motor and the QMP kit, you can get around 500-550rwhp and alotta tq pretty easily.... still with me? So the kit is performing well but at this level about as efficiently as it can... and it's maxed out.
Who buys tuner kits? Someone with better heads, intake, cam, bottom end, etc.. so they are already making way more power than stock (as in Warbird's case) and also have the potential to run a lot of boost and make a lot of power..... well this is where things go south. The QMP kit based around that log will never do what these people are wanting it to do.... and so they start having problems.... like overheating, losing boost....
Does that not make sense to anyone?
The car went from running low 13's at 100 mph to mid 11's at 124-125 mph. That was with an ill-shifting tremec (bought it used and got screwed.. synchros were junk) and no two-step. I am sure if i still had the car, and with my budget now, i would be giving you a run for your money at some Ford Vs. GM race
And as for my Ls1... well sure it is pretty slow compared to other cam'd cars (11.97 @ 115.8 1.77 60')... actually there is a whole list of stock cam'd cars faster than me. BUT i bought the car last november and everything i have done is in hopes of the next good turbo kit that comes out. The car is full weight and it will stay that way. I am not removing A/C or power anything nor my interior... and i don't plan on launching the car at 6,000 rpm's so my 60's will continue to suck while i stay N/A.
Oh... and Rob, Re; your PM.... as if i didn't think you were childish enough, are you now threatening to beat me up if you see me at the next car meet? If so then i really think you should withdraw that comment. Thanks.
-Jarrod
Back to the wastegate location... TT has it there to bleed off extra exhaust gases not needed for boost production... exhaust is a fluid so the pressure throughout the manifold is relatively the same.. this being said, both banks do indeed get vented just not in an ideal way to allow for constant one direction flow. For example, you have a balloon shaped like a "E", pop a hole in any one of the legs, and what happens to the pressure in the other legs?... well it lowers at the same rate, to the same level relatively speaking to right infront of the pin hole.
This same thing is happening when the wastegate opens, all of the pre-turbo exhaust piping loses pressure, not just the passenger side... AND now all of the exhaust that is being bled off does not have to go through the manifold first... so it doesn't impede the exhaust that actually will be used for boost production. Since it's not going through the manifold first before being vented, the overall backpressure of the system doesn't become a problem until a higher hp level.. THUS allowing the system as a whole to flow more overall.
If you want to get really technical, you will find (read the post from the Garrett turbo engineer) that dumping the wastegates exhaust back in right behind the turbos exhaust discharge is bad for flow as well. Your kit is like that.
I am waiting.................
The TT kit which is pretty much the same kit... does begin to have backpressure vs. boost pressure issues around 500-550 hp... again if there had been any testing, you would have found this.
and speaking of those numbers.... did you ever post up graphs of Shawn's and other cars where you "fxed" the power drop off issue? You said it was fueling.. or was it valvesprings... Either way post up a graph of a stock turbo car that doesn't have the power dropping off....
again i am still waiting.............
There were at least 30 local F-Body members at the track that saw my car run the 9.86. (go to www.kyfbodies.org and ask) Everyone looked at it and many took pictures. Exact same kit on my car that we sell....exactly the same as Warbird's kit. It's not responsibility to do anything for you. You just can't stand the fact that you WERE WRONG!
Regarding dyno sheets, the one you are referring to was done over two years ago by Ed Wright. The current dyno sheet from my car (tuned by me) has a flat 11:1 AF. Did you look at my Buick's dyno graph that I also tuned? I also have a perfectly straight 11.5:1 AF graph with 500rwhp on Jonathan's Trans Am that I can email to anyone who wants to see it. (I tuned it with LS1Edit, 1st time ever! How 'bout that?)But I'm not going out of my way to post it to the website just because YOU doubt me.
So please show us MM's 11:1 AF graphs. Because one of you is lying. He has always said that he didn't get an AF reading, which is why he didn't post his AF graphs. Remember that? He uses ATAP to tune his car.....again, ingenius.
Lastly, I never threatened "to beat you up". But I did say that I wouldn't put up with your **** for two seconds in person. FACT. And I still stand by that statement.
I'm sorry, I know it's rash for me to say, but all three of you are idiots. I get dumber by the minute just trying to talk to you.
Here are mine:
1) The QMP vs Warbird/MM/RiceEtr threads have be be toned down, folks have beat this to death and frankly all of the parties get too charged up to have a productive discussion. I am not going to allow folks to have a feud on our site for the next 3-4 years about this.
2) I called Rob and he offered to take pics of his piping to show that it's the same stuff that he uses in the production kits. I am glad to host pics for any of you folks.
3) Maybe Warbird's bigger motor acts differently than smaller cube motor but why do the threads have to be like little wars? I just don't see how this stuff has to be so emotionally charged, why didn't the upset folks simply take their cars to QMP and go from there?
4) I know of two other cars getting the QMP setups, one already ran on stock longblock and it did 450rwhp thru cats and stock exhaust. Both installs took 1.5-2 days. I did not seek out these cars but I happened to hear about them.
You give Rob the decency of a personal telephone call, but when I send you a "private" PM, you decide to publicly announce it. Talk about a double standard. We've actually met and talked a few times, you have clearly taken sides in this debate.
PSJ, did Rob offer you a free kit?
http://www.ls1motorsports.com/Single_Turbo.asp
at 7psi the 6 speed peaked at around 5200rpm, then at 9psi it peaked just shy of 5krpm.. turn the boost up to where i had it and you get a peak at around 4krpm
compare this to some of the old incon graphs and you will see them pull to the same peak rpm as it did stock.. this is a good indication that the engine is within the efficiency range of the turbo kit.
Rob, I ,for one, appreciate the support you try to give your customers on this board. I don't always agree with you but it has always stuck out in my mind that at least you offer some help when you can instead of just "take the money and run" like some folks do.Thanks!
