New Build - LS7 - D1SC - A/W - N2O
1998 Corvette - A4
Built LS7 (428ci)
- 8.8:1 Compression
- JE Pistons
- Eagle H-Beam Rods
- Eagle Crank
- ARP Main Studs
- Federel Mogul Bearings
- Hellfire File-Fit Rings
- ATI Overdrive Balancer
TEA/TFS 245cc Heads
- Stainless Steel Ferrea Valves
- .650" lift Gold Springs
FAST 90mm Intake Manifold
LS2 Throttle Body
Cam Motion 24X/24X .615/.615 114 LSA
PI 3600 Triple Disc Converter
Built 4L60E
Custom Return Style Fuel System
- RC 75lb Injectors
- KB BAP
- "Top Secret" Pump
- 10AN to "Y" Block, 8AN to the Rails
- FAST Fuel Rails
- Aeromotive Regulator
ATI Procharger - Polished D1SC
- ATI 8 Rib Kit
- Reichard Racing 3.5" Upper Pulley
- Stage 2 Upgrade Brackets/Tensioner
- ATI "Big Red" Bypass
- 4" Aluminum Charge + Discharge Piping
Precision Air to Water Intercooler
- Supports up to 1300 fwhp
NOS - 75 shot
Speed Density Tuning
Sorry about the TERRIBLE pictures. More to come by friday. Made a ton of progress tonight.
Procharger -
Procharger/Fuel System/Old Intake
A/W
All the Room
I promise the pictures will be better by Friday.
-Wade
Built LS7 (428ci)
- 8.8:1 Compression
- JE Pistons
- Eagle H-Beam Rods
- Eagle Crank
- ARP Main Studs
TEA/TFS 245cc Heads
LS2 Throttle Body
Built 4L60E
- RC 75lb Injectors
- KB BAP
- "Top Secret" Pump
- FAST Fuel Rails
- ATI 8 Rib Kit
NOS - 75 shot
Procharger -
A/W
All the Room
-Wade
Looks great! Just curious, why all the high end engine and drivetrain then stick an unworthy D1SC on the front? It'll hardly be breaking positive pressure with that big of a motor. Seems like an F1A-F1R would be better suited...
Built the motor, decided on the heads and D1 along the way. With the small twin intercoolers the IAT's were through the ROOF! Now we're too a point where I want it finished. The intercooler, motor, heads, 4" piping, 75 shot, everything is BEGGING for a F1. So it will come, but I want to see how far we can push this little D1. I'm spinning it a few hundred RPM less than max, so It should scream.
If it broke into the 9's pushing the P1, I cant wait to see what it does with the D1.
But yes, I know the concern and the limitations, but we shall see what this baby blower can do.
Even in a convertible.
-W
Dumb Ass Vette Moderator
Nice build. I also think the D1SC will not come close to feeding the 428. F1-C would be the smallest to use IMO. Do you have some more info on the A/W cooler and any other pics? What is your 'top secret" pump? If you have a big enough pump, there is no need for the BAP. The BAP is a band aid solution IMO. Keep us updated
Those are the worst pics ever Wade! I am the one building the system...got all the tubing done, now I just need to fab up a water tank. I'll take a better pic tomarrow to show the progress. We have it setup to spin the blower at max right now, but Im sure he will step up to an F1 blower soon. Car should run pretty good with the 100 shot on top of it for now.
I think Chris did an excellent job on the Mark 8 fan and custom brackets. Everything is starting to come together. We really didnt get to work on the car today but hopefully we can make some progress tomorrow.
-Wade
-Wade
The precision intercooler is not an off the shelf unit. It was custom built for me over a year ago for a different project.
3 3/4 W
11 5/8 L
7 3/8 H
4" In/Out
1" Water Fittings
I still have one left. We were going to use duals on the last project!
-Wade
3 3/4 W
11 5/8 L
7 3/8 H
4" In/Out
1" Water Fittings
-Wade
