cam selection for APS build
Currently my car has a stock bottom end with patriot cnc ported 243 castings. I have livernois dual valve springs with 7.425 pushrods. I have the stock ls6 intake with a stock throttle body.
I hope to have a forged 347 bottom end built this summer, but I want to go ahead and install the cam that I will need for this build.
I have a vig 3600 stall with 3:42 gears
I would like the cam to be a little choppy, but I want whatever is best for the performance of the setup.
thanks,
Brent
how much power you want to make, where do you want the power to come in, how treetable is this supposed to be, and how much boost to you plan on running?
be specific the more specific you are the more people can help and point you in the right direction.
You're also gonna need a lot more parts to go with the kit. youre definatly gonna need a new fuel system and the ls6 intake prolly aint gonna cut it much longer.
You can buy the factory cams show pretty cheap.
Here are the ling cams compared to factory.
2-03 ZO6 cam: 204/218 .551/.547 -117.5 LSA
Lingenfelter GT2-3 207/220 .571/.578 –118.5CL
05-07 ZO6 cam 210/230 .561/.557 –120.5 LSA
Lingenfelter GT7 208/230 .554/.546 –121CL
Now if you want more lope something with say 115lsa like some cams from Epp should be great. I wouldn't go under 115lsa but you can run just about any cam with the turbos although they might not be totally optimal. There is a big war /debate about what is best turbo cam. Some guys say no split, some reverse,some normal. More lift is usually always better and bigger lsa but again some argue that too.
I figure lingenfelter knows a thing or two about turbo cars! The gt2-3 was their old turbo cam. The gt7 is their new one pretty much. Its used in many many of their builds.
APS is running their really high lift gt11 in their own forged up 346 build. But you will be changing out valves springs a lot in that one! well over 600 lift.
Really if you can give up the lope that gt7 factory equivalent cam would be hard to beat. My car is easy to tune for the cam,zero surging ,pulls strong to 6500. No complaints.
yeah, my car is a daily driver(as long as it's not raining). Drive bout ten minutes to work every day and then I cruise around on weekends. So drivability is a must. That is the reason I am swapping from the Procharger to the APS. I want a quiet, smooth, and fuel efficient setup.
I am only gonna make around 8 pounds right now cause of the stock bottom, but after I throw some rods and pistons in it I will be looking for around 700 to the ground.
As far as the fuel system goes.............that shouldn't be a really big deal. I have the racetronix kit and 60lb injectors right now, I will get some fuel rails and regulator to mount up front, run a feed line and use stock as a return. I will also add a second walbro 255 in tank and have it come on with the boost.
As far as the ls6 intake goes.............How much boost can you run on it? I was under the impression that i would start lifting the ls6 heads before I had trouble with the intake.
The aps is quite the install lots and lots of hours but now that its done pretty happy with it. I did get a dud turbo which have to get fixed by spring. Kit otherwise was high quality, good manual and every nut and bolt is included just dont think you will install it in a weekend. I changed out my cam which was 221/221/558/558/114 lsa to the gt7. Course also changed out entire engine and heads. Sold off my tts longtubes . I had fast 90/90 so running it now. I like it can add the direct port options and will be adding direct port system in spring.
Nitrous and turbos can get along just fine.
As for driveablity and all that yeah off boost it drives like stock .I don't pay much attention to mileage. On boost the aps are audible and if I want them to be loud I just open my electic cutout. That helps power quite a bit as well. the car gets fairly loud loud at higher rpm I think due to running no cats presently. The aps blow offs were too quiet for me and were recirced so just got some non recirc type turbosmart supersonics.They are not installed but should be much louder. Find out in spring.
The cam I am running now is a 232/236 595/601 112 xer lobe.
I think I will pick up a z06 cam that would be a cheaper option.
what is the difference in the 02-03 zo6 cams and the 04 zo6 cam?
I have one on my car now and I was wondering if I am going to have enough clearance with the aps intercooler pushing everything back.
when I put the radiator in it didn't seem like it sat back much further than the stock. Half inch at the most. My factory radiator support fit back on with no problems.
OK back to cam talk lol
Ok you sold the d1 already. should take it out of the sig!
I have not had my car running more than three weeks or so and its away for winter now. Only finished it up and got it running too late in the season. It was getting way too scary to drive on the cold roads and worrried about getting caught in freezing rain.
So no idea if my car will overheat next summer. Usually we don't get that hot but sometimes we can be in the 90s for a few weeks in the daytime in july. We are pretty far up north. I would sure like if you can tell me if the ron davis works out as still might put one in and maybe an edelbrock high flo water pump as well. I think maybe taking out my power steering cooler in my upper rad hose might help with a thicker rad.
I think the aps did move things back a bit. A few tricks are run a 160 stat,set the fans to turn on way lower or you can install and override to run them anytime the car is on.
and some redline water wetter can help a bit too.
I have a theory with the aps and overheating . I think a few guys might possilbly have forgot to take out the aps intercooler shipping cardboard.It would be easy to do if using it to protect things when putting in the intercooler. Then with it between the intercooler and condenser it would seriously block airflow.! I had a grocery bag get in there on my 99 and cause some overheating with the car na till figured it out. One grocery bag!
Also there is deal in the manual where you have to cut the bottom bumper cover out with arches for air flow. Wondering if some guys are doing that step?
lol forgot about taking that out of my sig thanks
Yeah, I will let you know how it goes when I install the kit............It will be prolly two months before I get everything ready. I'm gonna send the manifolds and the hot side to get the jet hot coating
https://ls1tech.com/forums/attachmen...100_octane.jpg
Heres a video at 17psi on 50/50 91 and 100 octane no meth.
http://videos.streetfire.net/video/2...364_130663.htm
I believe the GT-7 is even better but the baby GT2-3 aint bad either.
Les
this sure beats what i did for my first cam. I saw one on sale and I purchased it....no research, nothing. Just got it cause it was on sale.........lol
It has a spot on the sheet about desired shift point, max rpm.
Wonder what the base aps kits pull to........or does that depend on the cam??
I like mine cause can put direct port on it.
