NEW PROJECT. Procharged LSX 1000WPH Daily Driven
just trying to figure out a good stepping stone.
Im only 20....
If i build this now... what will i have to do in the next few years... so im
trying to figure out what the best route would be.
maybe ill just build an N/A BIG LSX. do full suspension and drivetrain....
and then in a year or so ill tear the block down and put in dished pistons.
and then add the boost... idk.. but i need to make a decision.
im just wasting time sitting on my ***.
Have you ever driven a car with over 700 rwhp? If not I can tell you it will grab your attention and beat the crap out of you don't watch what your are doing.
Honestly, you can achieve all of your goals except the 1000 rwhp for about 10K to 15K, but to hit the "magical" 1000 rwhp is very expensive. If you ask MightyMouse how much did it cost him to hit the 1000 rwhp number, I think he told GMHTP roughly 80K - 100K including the cost of the car - keep in mind he did much of the work himself.
I think it is great you have the money to do both school and a big power build, and hitting over 700 rwhp is nothing to be ashamed of! But you may have to rethink the 1000 rwhp goal.
Here is something else to think of, the new ZR1 makes 620 hp at the crank - if it can hook it can run high 10s all day. 700 rwhp would put you in 9's or low 10's, trust me, there is not much out on the street that will out run you with that power.
Best of luck in your build and be sure to post some pictures!
Build a LSX 434 with low compression (fu2k tearing the block down) in a year wast of time and $ esp if you plan on FI.
Plan for the future:
Turbo, 8.5:1CR
Supercharged, 9.5:1
Think about a 6-bolt head if you plan on boosting lots of #s
ect...
To get in the 9s a low compression LQ9/LS2 402/8 and a turbo will get you there with some work.
You can use an LS2 block if you don't plan on beating it up everyday.
Honestly if i had my choice i would do an LS2 block, ET heads, GMPP Carb intake w/ wilson elbow, 105mm TB, and an ST80 1.1AR T6. That will spool like a mother and full boost will be around 3000rpm! You would need some meth and maybe a touch of racegas at the track, but that will deff get you into the 9s.
This is my .02 cents
Good luck and i am subscribing for sure. This is maybe the sickest build i have ever read about just cause you are 20 years old.
The build we did here would be a good way to go without going over the top. Bob
347, F1C, 8 rib SDCE tensioner setup, stainless 3 inch custom ORY and 4 inch custom catback.
first thing is the F series blowers are no where near "stealth". you hear the supercharger well before the exhaust. then, the radiator is within 1/2 inch of the blower inlet. no intake ducting or filter with the radiator(without the left side fan) and a/c condenser in the stock location. there is no way you will get more than 8 rib on it without some serious mods, let alone any type of cog setup.
the exhaust is not too streetable either, but we have gotten by with it so far. good exhaust is important to any performance setup and it usually makes noise.
fuel is the next issue. 1000 rwhp on pump gas is gonna be hard to get, but possible. you may want to consider E85. i currently am on 110, but will more than likely go E85 next season. chances are you are gonna need to go to a stand alone efi as well to make the system easier to tune and safety with your engine investment. BS3 or FAST would be wise choices, especially when you will need a injector bigger than 60#.
if i were you with the 1000rwhp streetable goal i would go turbo. they are usually quieter than blowers and do not have the drive issues either. pump gas or race gas tune, boost controller. you should check out Mightymouse's setup for good reference to a quick street car.
My issues right now with the F1c are first and foremost, noise. Its LOUD. The blower is deafening when driving next to it.
2. Intake screen. impossible in the 'stock' blower location. unless you severely cut and modify the radiator and radiator support.
3. I really want to step it back to the F1a. I think that because F1c is robbing more power, its sluggish down low. Really un-necesarry for a street car. Besides 8-900rwhp is more than enough. Its really only bragging rights to have over 1000 to the wheels. Not very pracitical IMO.
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
but im thinking a D1SC would be a nice addition to it... 750 or so.
But yea. i think im gonna do a street build, with some CCW's rather than bogarts...
I think id rather tone it back and do a clean build. try to build something reliable.
Dan
The D1SC is fairly quiet, even run a catted exhaust which is very quiet for 100 mile road trips. If I turn the boost up to 12# it will run 9.80's. The only weight reduction I have is wheels which is probably offset by the other items I have added.
Here is the recipe link. Just followed some proven builds from this site while adding my own personal touches from my racing background.
https://ls1tech.com/forums/forced-in...et-driver.html
no offense. but this kid (been there) is better off buying a base d1 kit and doing some learning while hes in school.
comming to a website like this its easy to assume certain things are easy because they are common.
i have aquaintances that were young and attempted big projects because they have more money than time.
they normally get about half way into the build and lose interest, or change hobbies, or decide they need a newer car, or girls get in the way, or they finish it and promptly go wrap it around a tree.
not saying that will happen, but it surely is the norm.
as far as you build. i would love to say its interesting and i am excited for you, but i was turned off to it all soon as i realized it was all hypothetical.
im 21, wish i could have a 6-700 hp car.. not happening any time soon.
But it sounds like the O.P. is changing his mind on what he wants to do, like i change my ****** boxers.
IMO, u need a little more research before you get your 1000whp car
out what i want. Ive got about 50k ready to spend. The only thing thats
stopping me is that im not sure its worth the investment. and im thinking
about getting back into older cars... so you guys will find out in the next
week or so. Right now im looking at a 69 HOSS vert, and a 66 Shelby like
my dad's.
Later.
