New car for 2009 build, D1SC/347
Old 05-04-2009, 10:44 PM
  #321
6 Second Club Moderator
LASTLS1's Avatar
Originally Posted by kp
Was going to go yo the NMCA race in Bowling Green this weekend and get some 1/4 mile times but the weather looked crap, decided to visit my parents in Chicago and since the weather looked good figured I'd drag the car along to Byron dragway.
It ran exactly what I though it would 10.05 @ 134 with a spark plug wire off (oops), 9.63 @ 140 (foot brake) and 9.55 @ 141 with a 1.335 60 foot (2 step/trans brake set @ 2800 rpm). It was super crowded so I packed it up after 3 passes, my goal was a 9.5x, could have probbaly got in the 40s leaving a little harder off the trand brake but I didnt want to wait another 2 hours to make another pass - especially being 700 miles from home.
Pretty nasty cross wind but the DA was a reasonable 1500 feet, that was on 50/50 93 pump and VP unleaded 109. The D1SC had 7.25/3.7 pulleys, peaked right at 14psi. I'm very happy how its running, I still have a bunch or weight I can remove and with a 3.4 pulley + bigger injectors and some better weather it will be a 9.20 car. But honestly I like it just how it is so I'll leave it for a while..
http://videos.streetfire.net/video/B...209_680308.htm
I wish I knew you were going to be at Byron, it's so close to me. I would have met you to see the car and meet you in person.
Old 05-04-2009, 10:54 PM
  #322
kp
kp's Avatar
It was a last minute thing, just happened to be going and the weather looked good so I thought why not bring the car..
Old 05-05-2009, 06:46 AM
  #323
Rickys S/C Z28's Avatar
It did run 9s
LOL!! yeah my bad!! LOL!!
Old 05-08-2009, 07:40 PM
  #324
LS1TECH Sponsor
Jon@BruteSpeed's Avatar
M9 is OK, on the plus side its light, torque arm clears everything nice. On the minus side I dont know who thought it was a good idea to put the vent on the top RH side of the housing, I had to rig something up to stop it from spaying gear oil out of the vent every pass and it still leaks. I dont know why they took the vent off the axle tube, never had an issue there. That and the TH400 crossmember setup with that funky trans mount adapter plate is pretty silly, not to mention I had to make a 1" thick shim to raise the trans up to get close to right driveline angle, they should make a dedicated TH400 crossmember instead of trying to make 4l60 one work. Arent you glad you asked
I will have to check out the crossmember for the 400, I'm sure Moser could come up with something different. I don't recall Bob having any problems, but he has a glide in his. Yeah, vent in axle tube is the way to go. That is where mine is in the 12 bolt.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old 05-08-2009, 09:43 PM
  #325
kp
kp's Avatar
The glide crossmember is fine since its made for a glide, I assume they make this one to fit a 4L60 and they give you an adapter plate to make it work with a M6/TH400. Which is fine except a TH400 needs to be spaced up quite a but over a T56 and they didnt take that into consideration I guess. IMO it would be better to just make a crossmember for a TH400. Its a decent piece overall though and its about 35lbs lighter than what I used on the last car and didnt really cost any more than a regular 9" housing, aftermarket torque arm and TH400 relocation crossmember.
Old 05-09-2009, 06:18 AM
  #326
EPP
EPP's Avatar
So far my M9 vent hasn't leaked at all. I'll mention it to Tim Irwin at Moser. Bob
Old 05-09-2009, 07:51 AM
  #327
kp
kp's Avatar
Maybe yours in a different spot, I used the little bronze vent they gave me and I knew that was going to leak where the vent is located. Not a really big issue just a few drops after a couple passes, I used a different style vent and moved it a little higher with an elbow, still seeps a little after a few passes but nothing makes it to the ground at least.
Old 05-09-2009, 08:35 AM
  #328
Brent@LPE's Avatar
Well.....................It leaks a pretty good bit. Nothing alarming though.
We can get it revised pretty easily.
Kevin your car is coming along very nicely you are going to be a high 8 second car again before you know it LOL!
Old 05-09-2009, 09:43 AM
  #329
kp
kp's Avatar
Mine would leave a little a few drops in the pits after every pass, plus a good sized puddle in the trailer on the way home. A few drops of gear oil on a smooth trailer floor looks huge after a couple hours. Alarming no, annoying yes, I dont know why they put it there. First thing I thought when I seen it is 'thats gonna leak' I was going to drill/tap the axle tube when it was out of the car but I figured they put it there for a reason..
I'm leaving it just like it is, if I dont race it I can drive it and wax it lol. Injectors are maxed out, if I decide to go faster then I'll do a BS3, but once I do that its 8.50 cage, chute, relocated battery etc and if I wanted to all that I should have just kept the last one.
Besides I picked up one of these the other day, not sure what I'm going to do with it but its an awesome car. I wanted one since they came out and so far I love it..
Attached Thumbnails New car for 2009 build, D1SC/347-g8.jpg
Old 05-09-2009, 10:55 PM
  #330
BTLBABY's Avatar
Nice choice on the new ride. The G8s are awesome cars, a good combo of everytnig!
-Coleman
Old 05-10-2009, 01:11 AM
  #331
kp
kp's Avatar
-Coleman
I was getting sick of the TBSS I had (cool truck but they ride like poo) and wanted a G8 since they came out. Dealer gave me great money on the TBSS and cut a good deal on the G8 so I figured I'd try one out.
Old 05-10-2009, 08:39 AM
  #332
LS1TECH Sponsor
I like the color.
__________________
Old 05-10-2009, 09:19 AM
  #333
White.Lightning's Avatar
Nice looking ride
Old 05-10-2009, 07:08 PM
  #334
frcefed98's Avatar
Nice G8 Kev, GT right?
My brother Eric picked one up too, and it is one impressive car. I want one but the lil woman doesn't
Leaving it stock?
J
Old 05-11-2009, 08:49 PM
  #335
kp
kp's Avatar
Leaving it stock?
J
Its a GT, I have little use for a V6 one
I'll leave it stock, plenty fun as-is, may do some different mufflers and a CAI since ts WAY too quiet. I had it up in the mountains the other day and was pretty impressed how it handled for a 4000lb car.
My wife loves the thing, surprised yours doesnt like it.
Old 05-11-2009, 08:55 PM
  #336
'Trust''s Avatar
Gah, I need to get some weight out of mine, I'm assuming we make similar power (7.65 and 3.4 pulley) but my 3966 raceweight sucks. GREAT job man, I'm impressed!
Old 05-11-2009, 09:02 PM
  #337
LS1 SPEED's Avatar
congrats!
Byron is a nice track and does work well and the reason I go there often
Old 05-11-2009, 09:33 PM
  #338
kp
kp's Avatar
I'm using the 7.25/3.7 pulleys so you are spinning yours a lot harder, but you are probably 500-550lbs heavier - that does have its negative effects on ET..
Originally Posted by LS1 SPEED
congrats!
Yea, its been about 15 years since I've been there, used to race there all the time. Not much has changed except you dont have to go to the tower to get your time slips any more
Old 05-11-2009, 09:43 PM
  #339
'Trust''s Avatar
Yea, good point. You have a sick build regardless though, one question. I'm not sure if you do it, but how is it driving around as far as exhaust noise etc. I'd love to quieten mine down.
Old 05-11-2009, 10:22 PM
  #340
kp
kp's Avatar
It was a lot quieter with the single 3" muffler, the 4" is pretty loud but its tolerable. If I was to drive it a lot I'd make a 4" to 3" adapter and swap the 3" muffler on for street driving.
Quick Reply: New car for 2009 build, D1SC/347
