Cam
Old Dec 14, 2008 | 02:01 AM
pewter2165's Avatar
Default Cam
What is a good boost cam?
Old Dec 14, 2008 | 11:05 AM
98catfish's Avatar
More info!
What form of FI? How much Boost? What size motor? What heads?
Doug
Old Dec 14, 2008 | 12:46 PM
98Z28MASS's Avatar
If you want a lopey cam or have larger than stock CI then the EPP FI cam is a good choice that makes great power. If you want smaller then the Lingenfelter GT-7 or the speed inc 225/225 FI cam is a good choice too. On a budget with near stock idle quality srick with the ls6 cam.
Old Dec 14, 2008 | 01:42 PM
pewter2165's Avatar
Originally Posted by 98catfish
More info!
Doug
8lbs of boost stock cubes and stock 853 heads.
Old Dec 14, 2008 | 01:59 PM
cablebandit's Avatar
get with PatrickG for a cam to fit your exact needs
Old Dec 14, 2008 | 03:00 PM
98catfish's Avatar
Zo6 cam will make good power.
Doug
Old Dec 14, 2008 | 04:34 PM
EPP's Avatar
EPP
http://www.exoticperformanceplus.com....html?item=679
Check out our blower cam in the above link. KP used it in hos black T/A, shown here.
http://www.exoticperformanceplus.com...html?item=1109
If you google "epp blower cam" you will come up with a lot of video of it. Bob
Old Dec 14, 2008 | 08:11 PM
lmt0705's Avatar
bobs blower cam is pretty mild sounding in my 408, although the only thing I can hear going down the road is the F1A
Old Dec 15, 2008 | 12:43 PM
pewter2165's Avatar
How much power will this cam do with a procharger and stock 853 heads? What should be my biggest concern with this set up? And if I stick with the cam in the car (TR224) any problems with it? -- thanks!!
