MTI Racing's LS1 F-body Magnacharger system now available for mail-order
Wow! Alot of responses and questions in one business day. Yesterday was extremely busy here at the shop so I wasn't able to respond.
Alot of the questions that are being asked are answered on our website. This is a link directly to our supercharger page.
http://www.mtiracing.com/artmaverick...argerkits.html
On that page there is also a link to track video of our MP112 powered LS1 camaro and the dynograph of our stock 2001 SS camaro with only our MP112 kit bolted on
The Frequently asked Questions page also answers alot of questions.
http://www.mtiracing.com/artmaverick...argerfaqp.html
I'll answer your questions so far.
-There used to be a company with a similar name in Houston. They were not affiliated with us. We are in GA and have been in business for over 15 years.
This is the same kit we have been installing in-house and we are now offering for the first time as a mail-order.
The only similarity of our maggie kit to the LM kit is that it's a maggie kit designed for an f-body. The cable system, power output, charger snout, fit and finish, and numerous other characteristics of our design are different than thiers.
Our system does require a 90mm throttle body. It is not included in the kit because most camaro owners with modifications already have this upgrade. If you do not already have one, we have these available as well.
If you have other questions which I have not addressed or are not addressed on our F.A.Q. page please submit them here. I will monitor this thread and respond as quickly as I can.
2002camaroSS Is this the same mti that was around a long time ago? Cause your website doesnt work anymore. I didnt know if you guys were still in buisness
LilJayV10 I think this is the kit they were trying to sell several months about but gave no real info on it.
If it's the same thing as the LM kit I don't see why they made it.
farmdawg The MTI kit is intercooled as well, but the LMSpeed kit includes a TB and the MTI kit doesn't.
Will this setup work on the LSX block. I would love to put one on a 427 or 454 LSX.
I know you said LS1. I am getting ready to build an LSX and was going to go all motor but love these style blowers.
#32
Any pics of how the intercooler works? I am wondering if going this route would be easier than a turbo. I have often thought of selling my Firehawk for a 03-04 Cobra. The sound is what puts a smile on my face.
Is this similar to the blower on the 03-04 Cobras?
I have read other threads that chargers that sit on top of the engine get hot and raise IAT's.
Is there a blow off valve and or clutch so when you let off the gas the blower doesn't load up?
The power numbers look pretty good. I think you should put some headers and good exhaust on it and see what it picks up.
The video on the MTI website with the blown Z06 is one of the sickest cars I have ever seen.
#33
This blower is way too small for anything, but stock cube ls1 motors runing up to only 11 lbs of boost and less with ported heads and intake and cam and exhaust. I will take a guess that the unit is maxed around 580 rwhp. Might be lucky to peg 600 rwhp. The nice thing is the torque curve.
#36
Apparently you're not waiting to ask MTI. The LMSpeed kit raises the body. To lower the k-member, it'll have to change mount points or as you said, totally screw up the camber. The magic of reality means you can't just take anybody's word for it. Even if he works at "a speed shop".
#37
The intercooler is air to water with two 5/8" heater hoses basically that come from the back of the engine to the front to run the water through the heat exchanger that sits in front of the a/c condensor.
There is an internal bypass valve that keeps the blower free-wheeling until the throttle get stabbed and the vac canister closes the valve to create boost so you won't be getting into boost cruising around town or idling in traffic.
The blower does create a lot of heat sitting on top of the engine and does affect your IAT's some, but a good tuner knows how to tune around it.
#39
An intercooler failure in this setup will result in coolant entering the head ports.
I have one of these blowers ready to install from LMspeed, just waiting on the rest of the kit to be shipped.
The MP112 setups do max out fairly early and will not give the peak numbers that alot of the other FI setups will give that alot are looking for. The off idle torque is insane though and they're reliable setups. Good for light to light racing and tire smoke shows. Exellent street and strip setups.
Decreasing the pulley size on the blower just results in belt slip and the intercooler becomes inefficient at higher boost levels no matter how big of a heat exchanger you put on.
This is what I hear though
#40
We have a 1994 camaro in which we installed an LS1 engine and our MP112 system. We use this camaro as a track car and run the overdrive crank pulley creating around 10.5lbs of boost. We have not observed any belt slippage. An upgrade to an 8-rib belt is always an option.
![](http://i268.photobucket.com/albums/jj31/MTIracingGA/MTIpic019.jpg)
