MTI Racing's LS1 F-body Magnacharger system now available for mail-order
Old 01-08-2009, 12:22 AM
  #61
cobrakillerta's Avatar
What kind of numbers will this set-up make on a full bolt-on car with stock cam/heads?
Old 01-08-2009, 11:54 AM
  #62
JC@MTI Racing's Avatar
Originally Posted by NemeSS
is the kit available minus inj., tune and boosta pump?
I can offer a $500 discount if you do not want injectors or the boost-a-pump. Since tuning is a mail order re-tune of your ecm rather than a hand held tuner, there is no discount for leaving the tuning out of the package.
The overall power numbers really depend on your current numbers and which bolt-on's you have. The dynograph I posted is from a vehicle with stock heads and cam but no bolt-ons. You should see similar gains with your car.
Old 01-08-2009, 12:10 PM
  #63
WLDWS6's Avatar
Is the Magnacharger MP122 supercharger system kit available for the F-body ? If so how much ?
Old 01-08-2009, 04:52 PM
  #64
Stephen@MTI Racing's Avatar
No, The 122 body is larger and encroaches into the windshield wiper area.
The MTI Racing system uses the 112 and is more than capable to push lots of power. Unless your goal is 700+hp, 112 should be fine.
Old 01-08-2009, 05:19 PM
  #65
LilJayV10's Avatar
I would like to hear from more people who had the kit installed.
Old 01-08-2009, 05:27 PM
  #66
WLDWS6's Avatar
Look at the first post. Heck look at the thread title.
I don't think you understood the Question !!!
They have a 112 and a 122 LM speed put a 122 on a f-body already.
That is way I was asking.
Old 01-08-2009, 05:35 PM
  #67
LilJayV10's Avatar
Man I apologize. I re read what you asked and I immediately changed it. I sent you a PM regarding someone making a 122 kit.
My mistake!
Old 01-08-2009, 06:02 PM
  #68
WLDWS6's Avatar
My mistake!
O.K. No Problem sent you a P.M. Back
Old 01-08-2009, 06:23 PM
  #69
LilJayV10's Avatar
Originally Posted by JC@MTI Racing
To show the values of just the added boost, I am doing some research on some of our previous installs which we did some dyno testing at different boost levels and I will post the numbers shortly.
Any luck on finding them? With the in house build you guys did where all the car stock or did they have different head/cam/exhaust combos?
Old 01-09-2009, 02:41 PM
  #70
I will contact the owners to see if they will post their feedback.
We installed an MP112 on a customers 2002 WS-6 who had a high mileage SLP 402ci engine. With the overdrive crank damper it produced 9lbs of boost. The car was an automatic which means an additional 5% loss of power from the flywheel to the tires thru the drivetrain. It produced 513rwhp and 531rwtq. Most impressively was that it had over 500ft/lbs of rear wheel torque at 2700rpm's. In a manual trans car these numbers would have been 539rwhp and 558 rwtq with 525tq at 2700rpm's
We installed this system on a M6 2001 SS which had a mild cam, some headwork, and headers. His set-up produced 503rwhp and 472ft/lbs of rear wheel torque with 7lbs of boost
Old 01-10-2009, 03:15 AM
  #71
LilJayV10's Avatar
[QUOTE=JC@MTI Racing;10815002]I will contact the owners to see if they will post their feedback.
/[QUOTE]
I think that would help business the most.
Old 01-11-2009, 12:12 AM
  #72
boysiner's Avatar
I would like to see lots of videos of this thing. Love the sound of the supercharger.
Old 01-21-2009, 11:56 PM
  #73
squee's Avatar
I'm about to sell my STS kit and get one of these Maggies, but I'd really like to be able to make more than 600 at the rear wheels without maxing it out and making the IATs outrageous. I already have a 383 built for boost (was built to produce around 1000rwhp with the turbo so it should be bullet proof) and was wondering what I could expect with the 383. I really don't want to have to build a 347 for it since I already have the 383 built and all. Do you think the 383 will be to much for the little 112?
Old 01-22-2009, 09:42 AM
  #74
The maggie is designed more for usable low rpm torque and horsepower rather than peak hp at high rpm's like a turbo. We have installed the 112 on a 402ci engine with an overdrive boost damper and it produced 9#'s of boost. What compression is your 383 running and how much boost are you looking for?
Old 01-22-2009, 09:48 AM
  #75
http://www.mtiracing.com/artmaverick...argedcama.html
Old 01-22-2009, 02:24 PM
  #76
squee's Avatar
Not sure one how much boost I wanna run. Just depends on how much boost it takes to get the power I want. The motor was built to run 25 pounds of boost, so it should be pretty much whatever I want. With the heads I have for it, it'll be right at 10.2:1 compression. I'm just hoping for 600-650 at the wheels without maxing the blower out and raising the IATs real high.
Old 01-23-2009, 12:57 PM
  #77
1BADTALS1's Avatar
if only i had 6k
sweet looking kit tho. one of these days i WILL have one on my car...
Old 01-23-2009, 01:19 PM
  #78
Mekkadon's Avatar
Originally Posted by N4cer
Learn to shift. You don't race from 4k rpm.
Yes, you do. And no, I'm not talking about frum rool street racing either.
Old 02-17-2009, 12:05 PM
  #79
Big Bird WS6's Avatar
do you have to cut the cal? and space the k-member down?
Old 02-18-2009, 10:29 AM
  #80
please help with question^^^^^
Quick Reply: MTI Racing's LS1 F-body Magnacharger system now available for mail-order
