Valvesprings / pushrods
Old Dec 30, 2008 | 10:08 PM
casey38boost's Avatar
Default Valvesprings / pushrods
I am swapping a 02 ls1 / 4l80e setup into my 67 Camaro.
While I have the oil pan off I was going to go w/ ARP rod bolt kit.
As of now I am going to leave the stock cam / heads.
What valve spring and pushrods would be recommended for a 70/76mm turbo set up. 6-10psi
Also part numbers would help.
Old Dec 30, 2008 | 10:24 PM
SPRAYED 01's Avatar
I would go with the Patriot Extreme springs. Exotic Performance Plus has a kit that includes,springs,tit retainers,seals,lockers for $275. Im switching from the patriot golds to the extremes. Push rods you can go a bunch of ways. I picked up some hardened stock length rods from Thunder racing like 3 years ago and 30k ago. They never really wear out and are cheap.
Old Dec 30, 2008 | 10:36 PM
U think the extremes are fine even with the stock cam?
Old Dec 31, 2008 | 01:35 AM
firehawk123's Avatar
yes it will be fine my car am runing a 408ci and s91 mm turbo and a big cam around 600lift in it and am using the extremes and they work fine .
Old Dec 31, 2008 | 02:12 AM
black98ws6ta's Avatar
Duals are overkill for a stock cam. Eventhough they will work fine you can get away with the comp 918 springs. A hardened stock length 7.400'' pushrod is what you are looking for.
Old Dec 31, 2008 | 07:56 AM
SPRAYED 01's Avatar
Dual might be over kill but for $275 for the entire kit you cant beat that.
Old Dec 31, 2008 | 02:15 PM
$ho_tyme's Avatar
Agree, plus there allready there when you decide for a bigger cam.
Old Dec 31, 2008 | 02:40 PM
Yeah I agree, just giving the option for $80 or so savings.
