My Truck Manifold Build
#42
Ran into some problems tonight. I need to fix my drain because if I slam on the breaks it smokes out the whole street must have a dip in it. Im guessing a restrictor in the feed line wouldnt hurt its -4 and seems to be pushing oil outta the exhaust after a hard run the drain is -10.
Valve cover breathers arent sufficent gonna run a vented catch can with no pcv. Both valve cover breathers were soaked and leaking onto the downpipe and smoked out the whole town.
Parish still running 6 psi.
3 inch but its fugging tight fit.
#43
#45
Oh Great LOL. Id like to change the whole setup from ls1-t56 to a 6.0 80e. But more work and money.
98camarod has the same probally just drenched the filters.
This ls1 has about 61k on it.
I have a old catch can air dryer that I gutted drilled and tapped a breather hole on that im gonna throw on there.
#48
single digit dreamer
i tried the whole catch can thing. wasn't worth the effort. i tried geting suction from in front of the turbo and still got oil into the intake track. i tried using an exhaust venturi. it might have been working but i am not sure. just a simple vent is the cheapest and has been working great.
#49
The vent is not working for myself, there are oil droplets all around my engine bay. I have two breathers, one on each side.
https://ls1tech.com/forums/generatio...ting-ok-2.html
Notice that these are for n/a routing and at the bottom of the page its suggested to run the clean side before the turbo. MightyMouse suggests to run it to the turbo port, which also seems the easiest to do.
#52
i worry a little about the capasity of the catch can. most of the catch cans i have seen have a pretty small line to them. how much air is that going to vent before the crank case presure builds and messing something up?
what happens with too much crank case presure? push oil past the rear main seal? blow the valve cover orings out?
