My Truck Manifold Build
Old 02-10-2009, 07:51 PM
  #101
blazin's Avatar
Im not excited at all to get a new engine. I will pry run the cam I have already.
Old 02-16-2009, 07:24 PM
  #102
blazin's Avatar
Well started swapping stuff over and finally figured out what cam it had. It wasnt the 224/224 like the pcm said. Its a g5x3 on 114.
What a pita. Havent even pulled the pistons outta the ls1 yet. Still swapping other stuff so I can get the 5.3 set in.
Old 02-16-2009, 07:45 PM
  #103
single digit dreamer
parish8's Avatar
you are quick to get things put together. then equaly quick to blow them up. do you have any plans of trying to make this engine last?
Old 02-16-2009, 07:59 PM
  #104
blazin's Avatar
Yea I hope so.
Old 02-16-2009, 10:43 PM
  #105
Black_98Z's Avatar
Anymore details on the alt setup. How it is mounted using the stock bracket and how the belt in tensioned etc.
Old 02-23-2009, 09:15 PM
  #106
blazin's Avatar
Well Havent got a whole lot of progress. Things im doing
Turn One PS Pulley
Finish Putting accessories on
Spohn Solid Mounts
2 Bar SD
Gonna be another week before it gets set back in waiting on a weld flange for the oil pan.
Old 02-24-2009, 06:28 PM
  #107
98Camarod's Avatar
Weld flange for the oil pan?
Old 02-24-2009, 08:05 PM
  #108
V10GTS's Avatar
cool build
Old 02-24-2009, 09:45 PM
  #109
blazin's Avatar
Tigging a 1/2 npt to the oil pan.
Old 02-27-2009, 10:41 AM
  #110
allbaugh_04's Avatar
subscribing..
Old 02-27-2009, 12:42 PM
  #111
blakern's Avatar
So hows it coming along?
Old 02-27-2009, 04:37 PM
  #112
blazin's Avatar
Motors ready to go in. Waiting to get the turbo back should be beginning of next week, oil pan bung needs welded for the return. Ill try to get some pics tonight. blakern any one around you know mig or tig aluminum tom?
Old 02-27-2009, 05:31 PM
  #113
98Camarod's Avatar
Why not just drill and tap it?
I sent you that link, did you get it?
Old 02-27-2009, 06:06 PM
  #114
blakern's Avatar
Talked to a buddy thats a welder @ a machine shop. He can do it for you Monday if that works for you. He lives in Kearney so let me know if that works for you.
Old 02-28-2009, 05:18 PM
  #115
blazin's Avatar
blakern: thanks but im going to do it at work on monday with a tig.
I already drilled and tapped it but with the motor out im gonna do it right and weld a fitting on there instead.
Here are some pics of the 5.3 ready to go in.
Old 02-28-2009, 05:31 PM
  #116
blakern's Avatar
looks nice. so did you find out what happen to the ls1?
Old 02-28-2009, 06:03 PM
  #117
blazin's Avatar
Not yet i havent really looked it over nothing visually broke. that i could see by just peeking in there.
Old 03-10-2009, 08:15 PM
  #118
blazin's Avatar
Motors in and running. Heading out to excessive auto in souix falls sd for a dyno tune. Should be interesting.
Old 03-10-2009, 08:18 PM
  #119
98Camarod's Avatar
just FYI, the breather tanks I got solve my problem
Old 03-10-2009, 08:21 PM
  #120
parish8's Avatar
woohoo, dynos are fun.
baby steps.
Quick Reply: My Truck Manifold Build
