Multiple Tees into manifold boost line, need some insight
this kinda got me worried and I thought of asking.
I just figured out that I got a bunch of tees on the intake manifold boost line, and a few on the brake booster.
on the manifold line, I got a tee going to the BAP pressure switch, fuel system pressure switch, fuel regulator boost referance, and finally the 2.5bar MAP sensor, which is mounted externally.
Then on the brake booster line, I got one connection with three joints, two going to the dual wastegates and one to the blow-off valve.
Im concerned about the accuracy of manifold readings with too much tees at least in the fuel system, boost a pump and MAP lines. I can't seem to figure out which has a more critical function for me to prioritize, but even if I did, what can I do about the rest?
My WG, MBC, meth control unit, boost gauge, etc. all work fine... The one thing that didn't work was my BOV... It would not pull it at all... That's the one thing I gave a dedicated line to and now it all works PERFECT.
http://www.mcmaster.com search vacuum manifolds
any here from 15 to 26 dollars for what we need
but suppose you use that splitter from one vacuum line for all sources you need, filling all or most of the ports... Would everything work okay? I've personally noticed some things don't mind being shared, like boost gauges and things that just need to read pressure to do their job... But would it be effective from things that need a good pull or push, like WG's or BOV's?
