Hey guys, Twin screw questions
#41
#43
So only Kenne Bell and Whipple actually produce a twin screw, is that correct? If so, then what actually signifies a twin screw. I thought is was the use of 2 separate impalers. If so, then I see several of these (certainly the TVS 2300) that have that design. Someone enlighten me here please.
#44
A roots style SC, like the stock Eaton, features two counter-rotating lobes that trap air from the intake side of the SC, move it around the outside casing of the lobes, and out the bottom of the SC through an outlet / discharge port. Acouple reasons why people like to get rid of the Eaton for a Twin Screw(KB, Whipple) is that the roots supercharger creates a lot of heat. There are two reasons for this. First, the roots SC does not compress air, it only moves from the intake port to the discharge port. And secondly, roots SC create higher amounts of heat is because they tend to carry some of the compressed air in the intake back into the SC because it gets trapped by the rotating lobes that are exposed to the hotter air in the intake manifold.
A twin screw appears similar to a roots style blower, but the differeneces are in the rotor designs. A roots has two equal style rotors that do not compress, instead they just draw in air. A Twin Screw's rotors, or "screws", mesh together and draw air from the back of the SC. The twin screw does not use equal style rotors, instead two different screw type "male" and "female" rotors. The twisting of these rotors move the air to the front of the SC, while compressing the air before discharging through the port towards the front of the SC. Because the compression is done inside the SC, this design produces less heat than a roots.
Couple visuals for you:
Roots style:
Twin Screw:
Hope this helps you!
#45
Great explanation RAZRS EDGE, I have a feeling that its only a matter of time before Kenne Bell or Whipple come out with a true twin screw for the LS7's. Then it will be OV for everyone on the street without one, lol.
#46
The Kennebell in a 4th Gen has been done already. the 2.8 fits with little modification, the real issue is getting one to work with a f body accessory drive. There is a way to do this, but overall you are looking at a 10k blower setup plus the cost of the motor.
If you have any questions feel free to ask.
#47
A twin screw would be great. Right now i think i just need a stepping stone. I'm gonna build the driveline... suspension... and other stuff i wanna do. Should be an interesting build. But im gonna build an NA 427 or 454. Then when i get bored with 600 or so WHP. maybe there will be a KB kit for the LS7 heads i can retrofit.
#48
#49
Obviously. Its not easy... Or else there would be a kit. Ive been searching for 2 months and ive only found 2 people that have done the kit.... Idk how well it turned out. Neither of them made a big deal about it.... So dont expect a link with step by step instructions on an install. Sorry. I may try in a couple years. LS7 Based 454 with a 2.8H.
#50
I know that both LM Speed and MTI have a kit out for F-bodies using the MP112... Im looking to build a ~402/8 with a twin screw. looking for a little more power than the MP112 can support. Is there a kit for the MP122?
or TVS?
or ill try a KB.
I know everybody wants me to go the 'easy' route and put a centri on it. but thats not really what im looking for.
i want over 700WHP, as a guideline.
or TVS?
or ill try a KB.
#51
Jim
