ATI Pin Kit, ATI Dampner Help.
I had a Procharger kit before along with my old ATI Harmonic Balancer that was pinned. I just want to confirm the correct way to pin the crank and balancer because I may have been told incorrect information the first time.
On the first kit I used the ATI pin kit and drilled the crank without the ATI balancer installed. I then installed the ATI balancer and lined up the square key way of balancer with the half moon key way that I drilled on the crank and installed the pin.
How do I go about installing everything this time around considering I already have the half moon key way drilled out on the crank?
Do I install the ATI balancer and line everything up the old way, no drilling?
Do I install the ATI balancer and drill both the balancer and crank?
Also, what bolt do I use for the ATI Dampner?
As for a bolt if you can afford it go with the ARP balancer bolt 234-2503. If not a new stock OEM bolt will work fine.
Also, I used the pin kit that you drill from the front that drills a portion of the crank and balancer, a half circle in each.
If I wanted to install another pin at 180* from the orginal, can I drill the ATI Balancer?
Where can I get additional pins from and what size?
Thanks,
Thanks,
Hold on, the ATI pinning kit drills vertically from the top, not horizontally from the front.
So I understand correctly, you have an ATI balancer today with a single square key way as it comes from ATI. Your crank has been drilled previously from the front, which is NOT an ATI pinning kit, and the crank has a single round half moon key way.
Is this correct?
Is this correct?
I have an ATI hub that has been opened up for the round procharger dowel, you can do that or buy the pin kit for the ATI balancer.
I have an ATI hub that has been modified to work with a round procharger key if you want to trade for yours, I have a square keyway in the new crank and cant use it
