Stock Bottom & Boost - Reliability List
Old Dec 11, 2010 | 03:51 AM
  #181
Snyper's Avatar
My stock block with 317s and a cam held up to 733hp, a daily basis *** beating and 2 over heats with 0 signs of damage or concern. Only reason for upgrading is because I have nothing to do over the winter and I want to run 20psi.
Old Dec 20, 2010 | 03:20 AM
  #182
IDRIVEAG8GT's Avatar
MP1900 Maggie @10 pounds on an L76 converted to non DoD, 221/226 cam, GMPP LS3 ported heads with more porting. Stock Converter. Etc, etc. installed at 20,000. Now at 32,000. My tune makes 601/588. Never broken once. Runs an 11.3 with street tires and its just my everyday DD that gets my fat *** to school and back.
Old Jan 20, 2011 | 06:50 PM
  #183
JustinStrife's Avatar
TYPE ----- BOOST -- RWHP -- INSTALL -- SINCE -- BROKE?
D1SC LS1
9psi
512rwhp
107k
131k
Still hanging on with the original longblock and clutch
Old Feb 2, 2011 | 02:25 PM
  #184
mulletnotch's Avatar
Originally Posted by mulletnotch
Stock LQ4, Custom Cam, Stock Heads, ARP Head studs and Rod Bolts, Precision 76mm, Through 4L80E:
11.5 LBS = 655 RWHP Pump and Torco Mix
8.5 LBS = 585 RWHP Pump Only
Sees 6800 RPM on the REGULAR
Been together for roughly 6k miles total about 4k of which were at 550 RWHP then the last 2k have been somewhere in the upper 500 range. Motor had approx 60k on it when I installed it and boosted it.
UPDATE: Twin 56mm billet T3 turbos, still stock heads and LQ4 shortblock - now running on E85. 713 rwhp through the 4L80E (unlocked converter).
Engine has never skipped a beat and is my only car - daily driven and enjoyed the way it should!
Attached Thumbnails Stock Bottom & Boost - Reliability List-e85-graph-1-29-2011.jpg   Stock Bottom & Boost - Reliability List-e85-over-mph.png
Old Feb 2, 2011 | 02:26 PM
  #185
Sorry 12.8lbs boost.
Old Feb 10, 2011 | 08:56 PM
  #186
XTNCTTA's Avatar
2002 Trans Am LS1 with Heads/cam
D1SC
7.5 lbs boost
520 RWHP
40,000 installed
50,000 current
No problems at all.
Dont be cheap with the tune
Old Feb 19, 2011 | 11:45 PM
  #187
brokegto's Avatar
Default stock bottom and broke
tvs2300---------10--------605--------39,000--------45,000------yes
hole in block peices of rod on skid plate
Old Feb 27, 2011 | 05:09 PM
  #188
1022hp's Avatar
nice thread
good information
thanks for all
Old Mar 6, 2011 | 11:21 PM
  #189
red 454's Avatar
HTV 2300 WITH INTERCOOLER
10.5 PSI
CAM 224X228
fuel system
FULL 3"DUEL SYSTEM
1-7/8,long tubes
15,000k now 30,000k
547rwhp
all still going
is my DD
Old Mar 10, 2011 | 03:19 PM
  #190
bluey2kz28's Avatar
Default Considering a similar setup...
D1SC LS1
9psi
512rwhp
107k
131k
How is everything holding up since you last posted? I ask because I am considering a similar setup on my ride and I have 108,000 on the clock. I will eventually also build a forged long block, but what I want costs way more that the D1SC setup. If the engine can withstand 12 to 18 months of this type of boosted existence, then it will buy me enough time to get the finances together for the forged engine and other goodies.
Old Mar 18, 2011 | 12:04 PM
  #191
Vetal's Avatar
Is there somewhere LS1 "hall of fame"?
Old Mar 22, 2011 | 10:19 AM
  #192
Orangemagic's Avatar
Mpt70
9-10psi
580rwhp-588rwtq
10 miles since install
stock ls6 with cometic gaskets and ARP studs, rod bolts and main bolts.
Old May 10, 2011 | 07:20 AM
  #193
c6matt's Avatar
Magnuson TVS2300
13.5 PSI
Stock 2000 Camaro longblock/ headers/ CAI
61000 now 61500
520rwhp/530 Tq
Old May 14, 2011 | 01:23 AM
  #194
donald green's Avatar
Default 825 hp
Originally Posted by hellbents10
Good tune and fuel and the rods will go first. Dave has been at 825whp with his Lq9 for 3k mi or so (one season, w/ a couple of dry street winter rides already lol).
what exactly did u have as power adder to make this power on lq9 ? i have 408 with 88mm made 818 rwhp on 10-12 lb boost,you can text me at 270 792 5025 and wanting to do a lq4 stock build in ta with boost is the reason for asking
Old Jun 3, 2011 | 11:03 PM
  #195
Fbodyjunkie06's Avatar
Precision 76GTSH, LS6 intake, 227/224 .570/.563 114, 918's, Chromoly Pushrods
635/587 11#'s (dynojet 10.8:1 AFR/T-56/12 Bolt)
Snow Boost Cooler (99% M1 Methanol)
55k now 88k currently
Old Jun 3, 2011 | 11:06 PM
  #196
tripblackls1's Avatar
Originally Posted by Orangemagic
Mpt70
9-10psi
580rwhp-588rwtq
only 10 miles huh? lol
Old Jun 4, 2011 | 09:23 AM
  #197
505OUTLAWZWS6's Avatar
Pt-88, custom cam, tsp pushrods, arp rod bolts, prc springs, and recently added arp head studs.
15lbs made 807 on e85 corrected at 5500'. A little over 700rwhp uncorrected.
Been on boost since 75,000 miles Od is around 85,000 miles.
Car has been 9.69 at 1.41 on 14lbs. Doesn't look like this list gets updated anymore.
Pt-88 ----- 15lbs ----700ish ---75,xxx ----- 85,xxx ---- N
Old Jun 11, 2011 | 08:47 PM
  #198
StatoJase's Avatar
Stock Ls1 long motor, set up with n/a comp cam, push rods, valve springs, timing chain etc.
edelbrock victor intake, blow thru carb, turbo 400 9" with 3.7 ratio
type : T trim vortech blow thru carb
Boost: 9-10psi
rwhp: 480rwhp/ 550tq
Install: retrofit has 3000 hard Kms on it 2 drag runs with tranny dramas
Not broken yet.
Old Jun 24, 2011 | 12:06 PM
  #199
ReD___RockeT's Avatar
Gt45r-18psi-762whp-130k-156k and still going strong.. Now I've had it nitrous, procharged, automatic 4l80e, and now its 6 speed t56, and the only problems I have ever had was tranny, drive shaft, and rear end.. And a few head gaskets. But I've had a variety of built heads on this block and different manifolds, and I built my turbo kit
Old Jun 24, 2011 | 12:30 PM
  #200
maxgee's Avatar
10k miles on my LS2
580rwhp/607rwrq on Dynojet
510rwhp/525rwtq on Mustang Dyno
9psi MPT70
