Stock Bottom & Boost - Reliability List
Old Apr 5, 2010 | 11:44 AM
  #141
cbr600rx7's Avatar
TTI 60-1
9psi 451rwhp 507tq with 60 trim falling on its face above 5000 rpms.
97000 when installed
101xxx now with no problems
Upgrading to T76 now
Old Apr 6, 2010 | 03:09 PM
  #142
zo6 vett's Avatar
Default #7
ptk style kit
04,ls6 stock
7psi just over a year,3500miles or so
87# compression,o leak down
#7 land between comp rings 1" piece ,stayed in place and run great.
blow buy was the indicater
mike
Old Apr 14, 2010 | 11:04 PM
  #143
Brett SS's Avatar
My standard LS1 bottom end is still going strong but it still hasn't been added to the original list, here are the current details:
Maggie MP122
10psi, 507rwhp
Miles at time of install - 59k
Miles on the car now - 73k
Broken - N
Standard bottom end is still running great and bores looked good when we installed Patriot LQ9 heads. It's had about 10 dyno runs in that time and about 10 1/4 mile passes with a best so far of 10.79@132mph so it's no slouch.
Old Apr 14, 2010 | 11:59 PM
  #144
MadIceV8's Avatar
Customizing Director
Brett SS - Thanks for the update. When I get some more time I will update the list.
Old Apr 19, 2010 | 11:29 PM
  #145
supersleeper01's Avatar
2001 c5
paxton sc600 kit
484 rwhp 516rwtq
34,000 miles installed
38,000 miles now
broken -N
Old Apr 21, 2010 | 09:25 PM
  #146
dadkins's Avatar
Stock 02 LQ9 installed valve springs only with around 98K on it, engine has around 102k on it now
Min Boost 17 lbs max 22
last dyno with T-56 was 825 RWH at 19lbs 5400 rpm on race gas,
Engine is now on E85 with an 4L80E going to dyno again tomorrow.
S374 74mm B/W Turbo
Just ran our best time 9.92 at 141.46 last Sat.
Link
http://www.ls1gto.com/forums/showthread.php?t=363838
Old Apr 22, 2010 | 11:41 AM
  #147
jfg455's Avatar
Originally Posted by ForcedInduction
- MasterPower T70 Turbo on 2000 Bone Stock 5.3 with 140k miles
- 10 psi last season/499 rwhp
- 108,xxx on truck 140,xxx on engine
- 3k miles on Turbo setup
- Have'nt broke any engine parts yet, but blew two TH400 cases. (That was my fault tho)
he is now at 18psi w/meth, 15* timing
broke a ring land (1/4 tank of fuel on a launch, went lean)
$40 ebay stock pistons back in
now at 567rwhp (4l80)
5K on setup
Old May 25, 2010 | 04:22 PM
  #148
GNXClone's Avatar
2006 GTO with completely stock LS2
- APS Twin Turbo
- 7.5 PSI / 554 RWHP / 574 FTLB
- Install turbo kit at ~21000
- Currently at ~46,000
- Motor was fine for nearly 2-1/2 years. I drove through some water and the low APS filters picked up water and hydrolocked my #7, breaking the wrist pin boss in the piston.
Replacing with forged, wet sump LS7 @ 9.25:1 compression
Old May 26, 2010 | 10:39 AM
  #149
Only ERO's's Avatar
Originally Posted by Only ERO's
Type Of Forced Induction: Procharger D1SC
Boost Amount / RWHP: 8 lbs / 475 (Mustang dyno)
Miles on the car when FI installed: 48000
Miles ran since FI installed: 6000
Bone stock '01 long block.
Only thing I have wrecked so far is the stock clutch. That went out at about 4500 miles. Hopefully the rear end will last long enough before putting a 9" in it.
I thought I would include an update:
I changed to the SDCE tensioner and due to the pulley ratio difference, I am seeing about 10.5 lbs of boost now. I recently had the car on a dyno and it saw 566 (numbers in my signature). The car currently has about 58,000 miles, or about 10000 since install.
No problems with the short block, yet. I am keeping my fingers crossed for now.
Old May 30, 2010 | 01:23 AM
  #150
bp944's Avatar
Nice. I needed to know the limit of the block and here it is. thanks
Old Jun 12, 2010 | 08:45 AM
  #151
firefighterusaf's Avatar
I'm running a P1SC on a stock bottom end 2001 Z, 7.5 lbs of boost makin 500 at the rear and it hasnt died on me yet. i do get a lag in the supercharger though, right around 2000 rpms. does anybody else get that same lag?
Old Jun 12, 2010 | 08:48 AM
  #152
maxgee's Avatar
I wouldn't call it lag, just not make power below 2k rpms.
Old Jun 13, 2010 | 02:57 AM
  #153
white01ss's Avatar
Turbos and roots blowers can make better power at 2k rpms, centris need more rpms.
Old Jun 23, 2010 | 08:56 PM
  #154
2002SLPSSCAMARO's Avatar
lookin for any advice on my kit...60 mm front mount kit for my 02 ss camaro...ls6...any thing i might need to upgraded...and who to have tune it in chicago area
Old Jul 7, 2010 | 05:59 AM
  #155
S2VYSS's Avatar
Do things like rod bolts improve the stock bottom ends chances of surviving much?
Old Jul 8, 2010 | 09:04 AM
  #156
white01ss's Avatar
Yes, but that's just one of the weaknesses. My stock engine made 540 rwhp and let go with two broken ring lands and a main bearing failure. Rod bolts wouldn't have helped me much. I drove the **** out of it though, your mileage may vary.
Old Jul 8, 2010 | 03:44 PM
  #157
maxgee's Avatar
Yes, friend of mine swapped out bolts on the rods and heads and did well over 100 1/4 and 1/8 passes with a 300 shot. He sold the motor in good working order to a bud.
To my understanding ringland damages usually occur either out of poor pcv set up and or running a little lean. The 1st one to go is usually #7
Old Jul 8, 2010 | 10:13 PM
  #158
danbap's Avatar
why is #7 always the first to go?
Old Jul 8, 2010 | 11:55 PM
  #159
NAVY99B4C's Avatar
It has the higest temps being in the back under the cowling
Old Jul 9, 2010 | 03:53 AM
  #160
S2VYSS's Avatar
So rods and head bolts, plus was planning on doing bottom end bearings, anything else without going all out on a forged bottom end?
