Stock Bottom & Boost - Reliability List
in process of building properly now, will find out what went wrong not too long from now...
-mpt76 q trim
-12 psi,ebay FMIC, 618/695 on 16*,e85, and really fat!!
-110k on car now,30k boosted miles total
-#7 is low on compression now and was low during the dyno runs.
100% stock parts on this motor
used z06 yellow springs,02 z06 cam,stock pushrods,stock timing.
it's all in the tune guys.
initial psi 6-7 and 450-500 rwhp and at 9psi/550rwhp since about 20k miles.
initial install 7K miles on car
Current Mileage 49,500 = 42500
on the 9psi tune it was overly safe, 11.5:1 a/f and around 16* timing at peak tq, and up to maybe 19-20 by redline. leaned it out to 12.5:1 on the dyno and gained no power, so we set it back.
Motor didn't break per se. Tore it apart to look for an engine tick; and found that I had an improperly heat treated cam that has a sliver of the lobe peel off the edge.
additional mods to motor were good pushrods and springs.
-APS Twin Turbo (Base kit)
-11psi / 630rwhp 640rwtq
-70k miles when installed
-78k miles current
Daily drive on 6psi but it sees 11psi about once a week for a quick thrill. Have made a dozen or so track passes on high boost, runs perfect. CMS SD tuning got me dialed in!
- Boost Amount / RWHP: 11.4 psi/708rwhp-640rwtq
- Miles on the car when FI installed: 13k
- Miles ran since FI has been on the car (ie: current mileage): 21k- IF you broke the motor, list what was broken: Never Broke Anything
Link to dyno vid:
https://ls1tech.com/forums/forced-in...deo-clips.html
Link to dyno vid:
Any track times?
Any track times?
- Boost Amount / RWHP: 10 psi/655rwhp-598rwtq
- Miles on the car when FI installed: 15k
- Miles ran since FI has been on the car (ie: current mileage): 25k
notes
11:1 CR
E85
Live in Colorado, 5,000 - 6,000 altitude
- Type of Forced Induction: Procharger D1SC
- Boost Amount / RWHP: 8psi 596hp / 508tq
- Miles on the car when FI installed: 42k
- Miles ran since FI has been on the car (ie: current mileage): 6k on setup, currently @ 48k
- IF you broke the motor, list what was broken: Nothing in the motor has broken.
Notes:
2001 Trans AM (Factory ls6 block), 6 speed.
--Mike
