Stock Bottom & Boost - Reliability List
Old Feb 1, 2009 | 05:27 PM
  #41
ProjecT 9's Avatar
- A&A Corvettes Vortech kit (T-Trim)
- 10lbs / 640/533
- 58,000 on installation
- 9,000 miles ran since (67,000)
- Blew the muffler off my car last night! Otherwise nothing.
Old Feb 7, 2009 | 01:58 PM
  #42
geeteego's Avatar
346LS1 GTO M6, stock internals
76GTS STS, Intercooled
Walbro 255 w/ BAP
???PSI boost
626rwhp/590rwtq
Installed, 43k
#7 ringland let go on dyno
Old Feb 7, 2009 | 03:54 PM
  #43
needaz28's Avatar
01 ws6,m6,ls6 bottom end,241 heads.
- 67mm sts set-up
- 10.5 psi, ebay fmic,meth / 550 rwhp,600+ trq. on high boost /meth
- 80k on car/@60k on ls6
- car has 102k/20k of that boosted
- motor still runs great/ doing a front mount set-up now.
a/f never went over 10.5:1
Old Feb 7, 2009 | 08:52 PM
  #44
MadIceV8's Avatar
Customizing Director
Thanks guys. I'll try to update the list on Monday when I get more time.
Old Feb 7, 2009 | 09:07 PM
  #45
allthrotle's Avatar
-D1sc on 7lbs
-523rwhp
-installed at 34,000
-since then 38,000
Only thing I've hurt is the stock 4l60e, other than that shes still going strong.
Old Feb 8, 2009 | 12:27 AM
  #46
boydcoz71's Avatar
T70 -------- 10 -------- xxx ------ 140k ---- 143k ----- N
i feel better now
Old Feb 8, 2009 | 09:24 PM
  #47
tirefryin_s10's Avatar
T76 ---- as high as 18.5 -----580rwhp through th400 on 16psi ---- about 8000kms--- still runs great.
Old Feb 8, 2009 | 09:40 PM
  #48
ElectronSS's Avatar
PT88 ---- as high as 18psi-----XXXrwhp through T56 on 4.8ci---- about 3k of boosted---11k on motor still runs great
Old Feb 9, 2009 | 05:35 PM
  #49
white01ss's Avatar
- D1SC
- 10 psi / 540 rwhp/490 rwtq
- Miles on the car when FI installed - 29,500
- Miles ran since FI has been on the car - 3500
- Motor Blown - puffing LOTs of air out the oil filler.
Old Feb 9, 2009 | 05:55 PM
  #50
Ryan K's Avatar
Pathological Modifier
Here are my results, I ran the **** out of it.
- Type of Forced Induction (Turbo/Supercharger) = Turbo 76MM on center
- Boost Amount / RWHP = 16-17# 580+ rwhp
- Miles on the car when FI installed = Unknown
- Miles ran since FI has been on the car = 10,000
- IF you broke the motor, list what was broken. = Ringlands 2 Pistons
Old Feb 9, 2009 | 09:39 PM
  #51
DarkFormula's Avatar
- Procharger P-1SC-1
- 13psi/588rwhp
- 36k
- 14k
- Nothing broken
Old Feb 10, 2009 | 01:11 PM
  #52
ChevyChad's Avatar
8 sec potential, 12 sec slip
Originally Posted by Jeezer
ouch was the car tuned??? pump or race fuel??
Yep, the car was dyno tuned and was about 12.0 AFR iirc. Pump 93 octane at the time. I have a suspicion that my failure may have been caused by possibly water getting into the engine thru the mecham hood and in thru the bypass valve on my old setup the heat extractor on the hood funneled water right onto the race BPV when i would get caught driving in the rain...
Old Feb 11, 2009 | 05:13 PM
  #53
shkettle's Avatar
2001 C5 Z06 WITH 10k when installed
24k now
kenne bell supercharger
8psi 560horse/over 500 ft lbs from2k-6500 rpm
no problems/ i drive it hard and track it
Old Feb 14, 2009 | 08:08 PM
  #54
maxgee's Avatar
505rwhp/536rwtq on 93octane
12k miles, stock bottom
8psi *with spiking to 10psi back to 8psi within a sec*
rich tune 10.5
I have an E85 tune I run every now and then and bump up some timing...don't know hp/tq numbers on e85 safe to say over 550rwhp.
Old Feb 14, 2009 | 09:57 PM
  #55
flyinmedic's Avatar
05 C6
D1SC 9psi
653/546
52K
54K
still going strong
Old Feb 23, 2009 | 07:13 PM
  #56
Spectre86's Avatar
- 10lbs / 640/533
are you on meth injection or just strait pump fuel?
Old Feb 23, 2009 | 07:35 PM
  #57
'Trust''s Avatar
I was bored, so incase anybody needed it, I re-arranged it so you can go by kit (alphabetical), boost within kit, and if they broken at the end of their respective kit list:
Originally Posted by MadIceV8
I am wanting to make a comparative list of how long the LS1 stock bottom end has lasted under boost and eventually make it a sticky. Generally I see everyone say 550rwhp, I just want to see how valid this statement roughly is.
So the people I want to reply in the thread are ones who have ran boost on a stock bottom end (pistons, rings, rods). Even if you broke something in the motor, still post up. Post only cars you own(ed).
Here is the format I'd like to see it in:
__________________________________________________ ________________
TYPE ----- BOOST -- RWHP -- INSTALL -- SINCE -- BROKE?
76gts ------- 12 -------- xxx ------ 55k ----- 60k ------ N
APS Twin --- 7 --------- 508 ------ 89k ----- 105k ---- N
APS Twin --- 8 --------- xxx ------- 21k ----- 35k ----- N
APS Twin --- 10 -------- 585 ------ 61k ----- 65k ----- N
D1SC -------- 7 -------- 500 ------ 29k ----- 39k ----- N
D1SC ------- 8 --------- 475 ------ 48k ----- 54k ----- N
D1SC ------- ? --------- 560 ------ 60k ----- 70k ----- N
D1SC ------- 10 -------- 612 ------ 0k ------ 11k ----- N
D1SC ------- 11 -------- xxx ------ 65k ----- 66k ------ Y
F1A --------- 6 -------- 540 ------ xxx ------ xxx ----- N
P1SC ------- 8 --------- xxx ------- 79k ---- 81k ----- N
P1SC ------- 10 -------- xxx ----- ~80k ---- 120k ----- N
P1SC ------- 7 --------- 489 ------ 28k ----- 50k ------ Y
PTS 67mm --- 7 -------- 507 ------ 35k ----- 50k ----- N
STS --------- 5 --------- 453 ----- 18k ------ 37k ----- N
STS -------- 5-8 ------- 460 ------ 61k ----- 75k ----- N
STS 67mm --- 10 ------ 550 ------ 60k ------ 80k ----- N
STS 76mm -- 5-15 ------ xxx ------ 109k --- 113k ----- N
STS --------- 7 -------- xxx ------- 80k ----- 5k ------ Y
76GTS STS --- x ------- 626 ------ 43k ----- 43k ----- Y
TC-76 ------- 9-10 ----- xxx ------ 26k ------ 32k ----- N
T70 --------- 8 --------- xxx ----- 82k ------ 85k ------ N
Vortech T ----10 ------- 640 ------ 58k ----- 67k ----- N
Old Feb 23, 2009 | 07:47 PM
  #58
SS2win's Avatar
- Incon Twin Turbo
- 6-10psi (EBC) / 425@6psi
- approx 25k
- approx 60k (85k)
- nothing broken so far but the clutch is due to be replaced. tune is FAT!
I drive it all over the country and so far it'all good.
Old Feb 23, 2009 | 08:17 PM
  #59
js2fst's Avatar
p1sc 7.5 lbs put on at 52k miles now at 107 k miles 450 rwhp originally next snow meth, zo6 cam, z06 valve springs, 8 rib, no dyno numbers yet but lost the rear and with z06 cam ran hard. Have 317 heads ported waiting till new motor goes in.
Old Feb 24, 2009 | 10:57 PM
  #60
white01ss's Avatar
Default Reposting
Originally Posted by white01ss
- D1SC
Still haven't made it into the list, but I KNOW the motor is toast! Probably a broken ring land like most folks, but I won't know for sure until I take the car in to replace the motor. Currently spending what feels like a fortune on a new motor in the worst economic environments of my lifetime. I guess I'm just doing my part for the betterment of the country .
BTW - This is one of the most useful threads I've seen in a while - thanks for starting it! If I had a better understanding of the limits of a stock block I probably would have lowered the timing a bit to reach "safe" hp levels.
Dan
