Stock Bottom & Boost - Reliability List
We plan on replacing all the essentials, such as the timing gear, chain, oil pump, valve springs, injectors, hoses, plugs...
What else should i think about? The car has been babied its whole life, and wont be spun over 4500 rpms.
Just my humble opinion.
made the number tho! lol. I told my tuner...**** that motor. I only wanted it to last 3-4 months. owell. its been 3-4 months, and the new motor is on its way. my advice on a stocker.....head studs, rod bolts, methanol, gaskets safe tune. 7-8 lbs max. that should help it live a good while. this car has been running for a few years now. this is also my same tuner. this is @ 17*
meth injection
arh long tubes
magnaflow exhaust
60# injectors
255 w hot wire kit
BONE STOCK MOTOR
575rwhp 535 ft lbs tq
installed 16000 miles
currently 21000 miles
broken NOPE
tuned by slowhawk
http://youtu.be/q3IkF9Zz7bU
D1SC 12lbs of boost
meth injection + 93 octane
cam, headers, catback
80lb Siemens injectors
installed @ 70k miles a year ago, now at 76k miles. Engine still good.
730rw/680tq
I do change the oil every 1300 miles or so.
- Type of Forced Induction T70 Turbo
- Type of fuel- Straight PROPANE
- Boost Amount 18+ lbs
- Miles on the car when FI installed 220K
- Miles ran since FI has been on the car (ie: current mileage) 225K
starts at 12lbs settles to 9lbs,
stock bottom ls1
ls9 headgaskets/arp studs @85ftlbs
317
E85
632/650 on a dynojet (@22* timing)
The car is at 19* now and it made these numbers with stock 853s, stock hg's, and stock head bolts. it blew the driver gasket and Idk what it makes now. probably the same.
installed at 48k at 50k now still going strong. only time I drive it is to beat on it
Dave was killed at Beeline Dragway? AZ around 1966 in a Chrysler AA Fuel, Don Gartlis clone. He was seen going through the traps head down, WFO. Speculation was the fumes from the Nitro and his WW2 gas mask didn't filter out the fumes and he passed out.
With this in mind, I hope my LS1 stays together with 11.3 to 1, 224*224*112* and 6? psi with menthanol and stock short block.
Thanks for listening, Dave was a real motor head and great guy.
Curt
If you look at "clean spot" I marked with an arrow, you will see where the rod was so folded up the the wrist pin/skirt area was touching the counter weight of the crank at the bottom of the stroke causing the chirping/clicking noise I heard after the pass. Neat stuff for stock parts. Needless to say we were very impressed with what the stock engine took and how well it preformed.
So the people I want to reply in the thread are ones who have ran boost on a stock bottom end (pistons, rings, rods). Even if you broke something in the motor, still post up. Post only cars you own(ed).
Here is the format I'd like to see it in:
- Type of Forced Induction (Turbo/Supercharger)
- Boost Amount / RWHP
- IF you broke the motor, list what was broken.
T76 Turbo
8lbs.
engine swap 73,xxx on engine
3,000miles
nothing broken, burnt up stock clutch of course.
http://www.ls1gto.com/forums/showthread.php?t=401429
dynoed at 780WHP
https://www.youtube.com/user/HIGHBOOST4G63?feature=mhee
