Stock Bottom & Boost - Reliability List
Old Mar 16, 2013 | 03:07 AM
  #261
red 454's Avatar
4 years on and and still running 10 psi ok so fare
Old Mar 16, 2013 | 06:44 AM
  #262
maxgee's Avatar
Originally Posted by B_ROCKS_IT
Running 13PSI on stock LS2, 4500 miles so far...
dynoed at 780WHP
https://www.youtube.com/user/HIGHBOOST4G63?feature=mhee
I'm impressed
Old Mar 16, 2013 | 10:38 AM
  #263
B_ROCKS_IT's Avatar
Originally Posted by maxgee
I'm impressed
As am I, was not the intention to go up that high, but when we were tuning it was pretty easy to keep that AFR's safe so we kept going...
Old Mar 16, 2013 | 11:13 AM
  #264
B_ROCKS_IT's Avatar
I'm impressed
What kind of numbers are you making?
Old Mar 24, 2013 | 01:34 AM
  #265
BMFB's Avatar
BROCKS, what are you running for fuel?
Old Mar 25, 2013 | 02:24 PM
  #266
LSX FOX's Avatar
stock bottom end ls1, stock 317 heads, Procomp head studs, gm head gaskets.
single t76 truck manifold kit, 15psi, 506hp/617tq @4300 then ran out of fuel(ve table is off)..getting dyno tuned tomorrow hoping for 650 on stock bottom end.
72xxx-76xxx miles no problems what so ever.
Old May 13, 2013 | 05:03 PM
  #267
Eddie Aop Benjamin's Avatar
what should my ls3 with forged pistons and lunati rods should handle ?
Old May 13, 2013 | 05:04 PM
  #268
stock crank
Old Jun 15, 2013 | 11:25 AM
  #269
PowerAdder's Avatar
Unforged engines are north of 800 rwhp.. so I think you will be fine.
Old Jul 17, 2013 | 09:46 PM
  #270
mrstepheneades's Avatar
Need to update the list lol. On first page of they thread. My results will be in soon. S475 stock heads and bottom end ls1.
Old Aug 4, 2013 | 04:00 PM
  #271
superstreeter's Avatar
I see all the #s here. but what are people running for timing ?
Old Aug 4, 2013 | 05:01 PM
  #272
red 454's Avatar
im running 16 deg max under full 10 psi boost at WOT
a friend of mine is running 18 deg max at 10 psi
Old Aug 5, 2013 | 07:34 AM
  #273
ig109's Avatar
Originally Posted by bonestock_442
S475 turbo
Lq4 iron block
15psi/822hp
12000mi install odo
13800mi now still running
Wish this guy would post up more info on his setup.. I see a build thread from a few years ago.. would like to know what all that thing has..
Old Aug 29, 2013 | 10:04 AM
  #274
Im on 16-17 psi pump gas and meth now. Stock untouched longblock ls1 with cam. Holding strong. More specs in sig.
Old Sep 12, 2013 | 10:37 AM
  #275
smokeshow's Avatar
Stock L76 short block, LS9 gaskets, head studs, cam/springs, pump gas and meth. Been beating the **** out of it for 15 months between 16-18psi. 4800lbs, went 133mph in the 1/4 on the street a couple week ago from hp tuners scan data. Good for 136-137 at the track with some tires and a ballsy driver.
Old Sep 27, 2013 | 10:52 AM
  #276
04cobralsswap's Avatar
What size turbo are most the guys running on 5.3 setups the s475 or s480?
Old Oct 4, 2013 | 08:51 PM
  #277
Bazman's Avatar
Stock LS1 4 door Commodore VT SS with custom STS rear mount 6275 T4 0.81AR
Made 550hp at engine/450rwhp on 5lb spring (peaked at 6.5psi) through 4L60E and 2800stall converter. Got 26mpg best on highway (31mpg imperial) and lasted 12,500 miles trouble free before decided to go to a 2013 LS3 swap.
Problems after tear down at 12,500miles:
1 - LS1 was down 25lb on 1 cylinder due to either detonation or water damage (water injection system leaked into intake.
2 - STS ball bearing turbo blowing smoke, so not impressed with their durability.
New LS3 in same car:
One basemap (no timing put in) the new LS3 made 522rwhp on STS turbo at 8lb before leaning out (running out of pump) so shut down. Since added a 2nd Bosch 044 pump but now the turbo blows oil intermittently so have yet to tune it fully with new Aquamist water/meth system and decent timing.
Now not sure whether to fix the poor durability STS turbo or get a new better turbo for the LS3 like a Comp Turbo billet CT43 6275 .81AR or a Garrett equivalent.
  #278
Bazman's Avatar
Problems after tear down at 12,500miles on LS1:
1 - LS1 was down 25lb on #3 cylinder due to either detonation or water damage (water injection system leaked into intake a few times turning it into a steam engine until it cleared itself). Engine still ran perfect though.
2 - Upgraded STS ball bearing turbo now blowing smoke intermittently, so not impressed with their durability.
Now not sure whether to fix the poor durability STS turbo or get a new better turbo for the LS3 like a Comp Turbo billet CT43 6275 .81AR or a Garrett equivalent. Want great torque from 2500rpm and around 560rwhp in daily drive mode at less than 10lb boost.
Old Oct 6, 2013 | 04:56 PM
  #279
755/663 stock 130k mile ls1 with tick cam.
Pump gas/meth
S475 turbo
17-18 psi
Installed 128000 and still going strong
No studs, bolts, gaskets, or anything. All in stock from factory form from year 2000.
Old Oct 20, 2013 | 03:52 PM
  #280
Forcefed86's Avatar
Ran all season about 100 slips, 1500 street miles. 160k OEM short block. Had 2 bunk pistons and I threw two random piston rod assys in. All OEM fasteners on rods, mains, etc. Also re angle torqued them all to OEM specs. Used original bearings and all. I did gap the original rings for boost. .025 on the top and .030 btm
Best of 9.04 @ 151 at 24psi. 15* of timing on E85.
Going by weight/trap speed that's 812 whp. 900+ at the crank?
