took the car out tonight and....
Old Feb 8, 2009 | 12:33 AM
01boydws6's Avatar
Default took the car out tonight and....
Well my car has been sittin all winter and I finally got it out today to take it for a drive. I did a few 3rd and 4th gear pulls and the car felt ok but as I was watching the boost gauge I noticed a few times it was'nt showing any boost and then when it did show boost it was only showing a few pounds. Any ideas??
Old Feb 8, 2009 | 01:05 AM
code4's Avatar
if you think it was running like it did before you parked it, maybe your guage is bad.
Old Feb 8, 2009 | 02:43 AM
Sweet71's Avatar
Wastegate issue? Stuck open maybe??
Old Feb 8, 2009 | 02:49 AM
jsteele90's Avatar
check your vacumn line for your boost gauge maybe its dryrotted or something
Old Feb 8, 2009 | 06:31 AM
ls1290's Avatar
Dumb Ass Vette Moderator
If the car felt 'OK', then I am guessing it is the boost gauge. If the car was not making boost, you would notice it.
Old Feb 8, 2009 | 06:50 PM
01boydws6's Avatar
thanks guys
Old Feb 8, 2009 | 06:58 PM
elias_799's Avatar
what turbo kit do you have ? you might have a cracked exhaust manifold.
Old Feb 9, 2009 | 06:46 AM
01boydws6's Avatar
I have a d1 procharger
Old Feb 9, 2009 | 05:32 PM
elias_799's Avatar
the only thing i can thing of is to check the piping from the compressor and the throttle body to see if you have a leak anywhere, also how is the belt for the sc looking ? . if the car feels strong it is probably just a boost gauge problem.
Old Feb 9, 2009 | 06:18 PM
BLOWNBLUEZ06's Avatar
I agree. Do a boost leak check by capping off the inlet and hooking up some air to it. When logging my car, I noticed it was down about 4psi. I performed the test and found that my bypass valve was stuck open ever so slightly.
