who sells/makes t trim brackets
Old Oct 9, 2003 | 08:10 PM
mike m's Avatar
Default who sells/makes t trim brackets
i am going to switch over after the winter. i am already at max impeller speed. 2nd would a t trim off of a 5.0 mustang work on our cars?
Old Oct 9, 2003 | 08:48 PM
stealth's Avatar
Default Re: who sells/makes t trim brackets
Call RMCA in Colorado Springs. CO. Vortech also knows their #.
Old Oct 9, 2003 | 08:51 PM
ChrisB's Avatar
The T-trim should fit fine in a s-trim bracket, I am not sure about the g-trim though. I am not aware of any off the shelf brackets, you will have to have one custom made. I know Chris Sikora has made a few custom ls1 blower brackets.
Old Oct 10, 2003 | 10:17 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
ChrisB, the T-trim won't directly fit into the LS1 bracket setup.
Chris Sikora made my brackets and they were per my request overkill city... 1/2 inch steel. I know he would not be as pricey at RMCR.
I think he could also take your G-trim brackets and either modify them or make you new ones. I would just make new ones... So you could mount the T-trim up high or down low.
Old Oct 10, 2003 | 10:19 AM
stealth's Avatar
I am using heavily modified T-trim brackets from RMCR on my Ys-trim.
Old Oct 10, 2003 | 03:39 PM
mike m's Avatar
ok so how much around would it cost for everything i need, if i have the t trim already?
Old Oct 10, 2003 | 04:25 PM
stealth's Avatar
~$1500 +/-
Old Oct 10, 2003 | 05:19 PM
Fast SS on TNT's Avatar
Thanks for posting this. I am going with a T Trim, and asked the same question in another thread.
RMCR? #?
Old Oct 10, 2003 | 05:23 PM
LS1Tech Co-Founder
Chris Sikora can do the brackets for less than that and he uses thicker steel. My brackets are stronger than my engine block.
I can email Chris' work number to those who are intersted.
Old Oct 13, 2003 | 12:35 PM
Shoot me his number PSJ, when you get time.
Old Oct 13, 2003 | 12:42 PM
LS1Tech Co-Founder
Email sent.
