what Compression ratio are you Turbocharged guys Running?
Old 02-14-2009 | 01:52 AM
52172's Avatar
Default Compression
Well 9:8:1 up to 20lbs of boost with octane. Check sig for pump 91 octane Sorry I cant post times.. track is far away and the po po is plenty.....
Old 02-14-2009 | 02:40 AM
LS2Camaro's Avatar
I am running 8:5.1 with 15 pounds of boost with a S85 turbo on a LS2 built bottom end. No meth here. I am seeing 717rwhp with this setup.
Old 02-14-2009 | 03:52 AM
matt_paco2010's Avatar
street cars are great between 9.0 and 9.5. I though 6.0litre LS2s were about 9.6:1. Very popular to turbo!
Old 02-14-2009 | 06:34 AM
Sluggish's Avatar
8.6:1 here . I think MightyMouse runs like 8.1 with his 88mm.
Old 02-14-2009 | 06:50 AM
cablebandit's Avatar
Originally Posted by 01SOMm6
Thats what I like to see! Ive been looking at your threads to. How much power do you make and at what Boost level? Also I think I seen you have 1.32 A/R When do you see full boost? I was looking at the same turbo you have but with the 1.10 A/R
15 deg of timing and 112 octane ....we were planning on high boost but never got there on the dyno which is why i had the 112 octane:
7 psi =720rwhp dynojet
9 psi=780 rwhp dynojet
at the track it went 9.59@144 on 12 psi...3950# raceweight
full boost is at 5000rpms at the track....takes 1 sec to get there from the starting line leaving at 3000rpms on the 2 step
Old 02-14-2009 | 08:13 AM
30th t/a's Avatar
8.6:1 CR, 15psi, 16* timing, 93 octane
Old 02-14-2009 | 08:26 AM
01SOMm6's Avatar
Thanks, those are the numbers Im looking to make. I dont think Ill see past 12-14psi. I do more racing off the track so I think Ill go with a 1.1 A/R. I think are raceweights are pretty close also.
Old 02-15-2009 | 03:48 PM
Sandmann120's Avatar
I've got about 11.2, and I'm looking at running straight methanol with a large-frame turbo on stock cubes.
Old 02-17-2009 | 07:31 AM
Fireball's Avatar
I'm right around 9:1
Old 02-17-2009 | 12:22 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
I just wrote up an article for GMHTP... 2005 GTO, 403 cid, 8.6:1, A4, hitting 680rwhp on a Dynomite dyno using 91 pump gas.
Old 02-17-2009 | 12:35 PM
ZO6 LandRocket's Avatar
Can you run 10:1 if you limit your boost 9lb or 10lb?
Old 02-17-2009 | 12:45 PM
  #32
01SOMm6's Avatar
look up Cablebandit, I think he said 10.4:1 on his S488. Thats about how my build will end up.
Old 02-17-2009 | 01:05 PM
  #33
SSilverSSurfer's Avatar
8.8:1 347 T76 eboost2 is showing 17psi i need to change the wastegate spring out and cause it wont go lower than that, lol
Old 02-17-2009 | 01:18 PM
  #34
98transguy's Avatar
8.5-1 383 ls1 s91 turbo 20psi on c16 = 900+rwhp,875+rwt
