First passes with KYTP kit (stock block)!
Old Feb 16, 2009 | 07:28 AM
Shoaf85's Avatar
Default First passes with KYTP kit (stock block)!
I figured some of the guys considering putting a turbo kit on their car are always looking for a video like this. I know I did when I was considering it. The first link has more info on the car and the video!
https://ls1tech.com/forums/drag-raci...down-runs.html
straight to the video:
http://www.youtube.com/watch?v=H0hPMuMzRS8
Old Feb 16, 2009 | 11:27 AM
DanZ28's Avatar
Fixed the link for you http://www.youtube.com/watch?v=H0hPMuMzRS8
Nice time..
Old Feb 16, 2009 | 12:17 PM
ItsNotStock's Avatar
That is one loud turbo. Nice run man. By stock block are you insinuating bottom end?
Old Feb 16, 2009 | 02:54 PM
Shoaf85's Avatar
yes stock short block down to the rod bolts!
Old Feb 16, 2009 | 04:39 PM
Do you have a back up engine? Lol. Thank god for the E85.
Old Feb 16, 2009 | 05:34 PM
elias_799's Avatar
do you have any engine bay pictures ?
Old Feb 16, 2009 | 05:51 PM
Jon@BruteSpeed's Avatar
LS1TECH Sponsor
DAMN!! Bad ***! That thing is getting down the road!
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old Feb 16, 2009 | 06:06 PM
dreamls1's Avatar
Very nice! How much hp you putting down? That's the same turbo I am running, can't wait to start it up.
Old Feb 16, 2009 | 07:28 PM
SPRAYED 01's Avatar
What did it run.is that a truck manifold kit
Old Feb 16, 2009 | 08:26 PM
code4's Avatar
looked like a 6.6 @105 in the 1/8.
Old Feb 16, 2009 | 08:33 PM
sevanseriesta's Avatar
that is awesome congrats
Old Feb 16, 2009 | 09:32 PM
OUTLAWZ RACING's Avatar
Woooot got to love that boost!
Old Feb 16, 2009 | 10:41 PM
Rickys S/C Z28's Avatar
wow man hat bad ***
Old Feb 16, 2009 | 10:50 PM
enginjoe's Avatar
I'm telling you, if E85 is available, every turbo street car should be running it. 105 octane, sucks the heat out of the intake charge and no knock. I know I do on the skittle. When I get the SS back up, it'll be on E85 too.
Old Feb 17, 2009 | 12:31 AM
Josh@KY-Turbo's Avatar
6.0L manifold setup.
TC76
38mm WG
8lbs
E85
Last I talked to him he was making over 580rwhp.
Old Feb 17, 2009 | 06:09 AM
Shoaf85's Avatar
Yeah the car made 590 rwhp w/ just under 7 psi. on a mustang dyno. But the compression is 11.5 that is why I am running E85! It also made that power at 5900 rpm. I have the limiter set at 6100 and I didn't want to hit it on the dyno! These numbers were made when the car was a 6 speed and I haven't had it on the dyno since the auto swap but I'm sure it lost a good bit through the th400. I can only imagine what the car will do with another 1,000 rpms and 10 more psi
Shoaf85's Avatar
I don't at the moment but I can get you some after work!
Old Feb 17, 2009 | 06:32 AM
needaz28's Avatar
TC76
38mm WG
8lbs
E85
I would of thought a 38mm is to small. I'm putting a mp t76 on mine but was told I had to go atleast 44mm. I have a 38mm sitting in the garage. seeing is beliving and it looks like a 38mm is working just fine.
Old Feb 17, 2009 | 07:38 AM
blu1's Avatar
Bout time
I'll be seeing you at the track again soon, this time I can't compete haha. I sold the nitrous kit so you got to give me the hit next time haha. Looking good and sounding sick man!
Old Feb 17, 2009 | 10:05 AM
Shoaf85's Avatar
IMO I would go with the 44mm at least. I have a 5 psi spring in it and it creeps to just under 7 psi! If you want to keep your psi stead at lower boost levels you will definately need more than a 38! I may end up adding a second 388mm to my set up!
BLU, yeah finally put it to use and hopefully we can get up at the track soon!
