what machine work to get done
Old Feb 16, 2009 | 02:05 PM
acidrain088's Avatar
Default what machine work to get done
im building a turbo motor on a budget here. so far i have an lq4 with 317 heads. no idea how many miles on the motor but the cylinders still have noticable crosshatching here. the motor was never taken apart before and is in great condition. what would u guys suggest i get done on this motor before replacing the rods and pistions. atleast a hone from the machine shop? or .0005 over. should i get it balanced? someone also mentioned that i should deffinetly get the crank knife edged. what would u guys do here?
Old Feb 16, 2009 | 02:41 PM
Fireball's Avatar
how much power you plan on pushing?
line bore/hone, truing up the decks, honing with a torque plate at a minimum...
Old Feb 16, 2009 | 02:44 PM
Johnv's Avatar
Forged pistons, (dished to give desired compression ratio) a good set of rods with ARP bolts, balance rotating assembly, ARP mains stud kit, ARP head stud kit, double row timing chain, molly push rods, dbl valve springs, GM MLS head gaskets, and maybe an SLP oil pump for a bit of extra insurance .
Old Feb 16, 2009 | 02:45 PM
i hope to be 800whp+ eventually
Old Feb 16, 2009 | 02:53 PM
Fireball's Avatar
I'd consider pinning the mains too then....
Old Feb 16, 2009 | 03:00 PM
what exactly is the purpose of that. just so they dont slide around.? thought that was just an aluminum ls1 thing
Old Feb 16, 2009 | 03:07 PM
Fireball's Avatar
its any LSx type of thing...at higher power levels the caps can walk around...pinning keeps that from happening.
Old Feb 16, 2009 | 09:05 PM
anyone with opinions on kinfe edging or balancing?
Old Feb 16, 2009 | 10:37 PM
BigRich954RR's Avatar
Have to get it balanced or it will rip it self apart. knife edging not worth the money if being built low cash
