Oil feed?
Old Mar 7, 2009 | 08:37 PM
dreamls1's Avatar
Default Oil feed?
How is eveyone running their turbo feed and return lines into the block? I need pics!
Old Mar 7, 2009 | 08:42 PM
Speed's Avatar
Look above the oil filter. There are 2 10mm bolts holding in a little casting with a part sticking out of it (used for the oil pressure sender on c5s). Drill that out, tap it with an 1/8th npt tap, screw in the fitting and you're done!
Old Mar 7, 2009 | 09:11 PM
dreamls1's Avatar
So both feed and return go in this spot? Does the bracket come off or do you tap into it?
Old Mar 7, 2009 | 09:15 PM
Speed's Avatar
No, just your feed. Return requires you to either gravity drain or pump back into the engine. Most either drill a hole in the oil pan or timing chain cover and put a -10 in it. Some using a scavenge pump to pump the oil into the oil fill on the valve cover. I've down it both ways and they both work. Scavenge pump makes the install much easier but it has additional cost and adds another component to fail. If the engine is out, there is not really a good reason not to do a gravity drain.
You can also use the same pump to create a self contained oil system as well. Some rear mount guys do this. If you search through this forum, you'll find more info on oil management than you will ever want to read.
Old Mar 7, 2009 | 09:33 PM
dreamls1's Avatar
So you can drain anywhere in the block?
Old Mar 7, 2009 | 09:37 PM
red83's Avatar
From: sneaking in your back door as you leave!/cartersville ga
drain in the oilpan of front cover. not the block
it must be above the oil level of course
Old Mar 7, 2009 | 09:39 PM
red83's Avatar
and here is your feed. if you dont have the tools to do it yourself.
https://ls1tech.com/forums/sponsor-s...ter-plate.html
Old Mar 7, 2009 | 09:55 PM
dreamls1's Avatar
Anyone have pix of their setup?
