Camaro SS F1-C Build
Old 03-17-2009, 05:02 PM
  #41
AFASTYZFR1's Avatar
Originally Posted by charged 434
I just installed a f1c on my camaro. same set up as you have i hope that it last a little while also. i ordered a 5" pulley. change your head gaskets to .095 . thats what i did, hope that helps a little good luck can't wait to see what happens
have any pics?
Old 03-17-2009, 06:19 PM
  #42
charged 434's Avatar
yeah i just put a few on last night i guess just look at my profile
Attached Thumbnails Camaro SS F1-C Build-camaro-016.jpg   Camaro SS F1-C Build-camaro-017.jpg   Camaro SS F1-C Build-camaro-021.jpg
Old 03-17-2009, 06:20 PM
  #43
i just installed the intercooler today and all the plug wires i will have pict of that tomorrow
Old 03-18-2009, 08:27 AM
  #44
SLOW30th-TA's Avatar
any info on the fuel rails/ fuel delivery set up to support the sc?
Old 03-18-2009, 10:57 AM
  #45
Frost's Avatar
stock rails (which are all that is needed), Racetronix pump and harness, 42lb SVO's, and Alkycontrol methanol
Old 03-22-2009, 08:56 PM
  #46
AFASTYZFR1's Avatar
Got radiator in
Old 03-23-2009, 01:28 AM
  #47
SELLSZ06's Avatar
Looks good! when I did mine, I tried mounting the radiator slanted like that, but it would get hot, bc air couldnt flow through it enough, especially with the condenser in front of it. Had eventually to do the vertical radiator mod.
Hopefully you get by without the same problem I had.
Old 03-23-2009, 10:15 PM
  #48
kkslds's Avatar
Who makes that meth kit using that containor? Lookin good so far
Old 03-23-2009, 11:32 PM
  #49
02NBMFormula's Avatar
alky control
Old 03-25-2009, 04:32 AM
  #50
whiteboycntdnce's Avatar
Hoping to be behind the wheel this weekend!
Old 03-25-2009, 01:46 PM
  #51
AFASTYZFR1's Avatar
Still working on it, but here are some more pics
Old 03-25-2009, 03:54 PM
  #52
MiaSSmaro98's Avatar
very tight space
Old 03-27-2009, 10:24 PM
  #53
AFASTYZFR1's Avatar
Basically done:
Old 03-28-2009, 09:18 AM
  #54
00silver6's Avatar
awsome build cant wait till you start that beast. I always wonder how you guys cut that front mouth so clean? nice job
Old 03-28-2009, 05:33 PM
  #55
EPP
EPP's Avatar
Thumbs up
The whole build looks very good. Bob
Old 03-28-2009, 10:55 PM
  #56
Frost's Avatar
AFASTYZFR1 and his buddy Patrick really did an incredible job getting this in for Tim.
After a rough start tuning this AM across town, I got down to where Tim's car was. The guys were just getting done with the very last touches. On top of the blower install, there was the intake swap and a significant amount of rewiring. The work was top notch.
Since the car had already been tuned in 1bar SD, the move to 2bar was really easy. The guys were so thorough that there was not one mechanical issue or thing to adjust or to have to stop to fix, nothing, uninterrupted tuning.
The 42lb Injectors are static at 5400 RPMs even with the meth CRANKED (2 #10 nozzles). From there we begin to drift north in AFR of the 11.2:1 that we are commanding. The combination of the 7.25" crank pulley and the 5.25" blower pulley netted us 8.5psi @ 6,000 RPMs with at 11.7:1 AFR. Since this is a relatively high compression engine (AFR 205s milled to 60cc and COmetics 0.040" compressed head gaskets), even with the meth, the timing is kept very conservative at 12-14deg. Up top where it starts to wander lean, the timing falls very low in case he touches that region spinning before his 60lb injectors get here this week. With the G5X3 on a 114LSA that is in the car, it didn't peak N/A until about 6,500. If that's the case here, after looking at the boost plotted on the VE, it looks like it should make right at 9psi at 6,500. This is a little more than we hoped for unfortunately, but a bottom end was already in the near future.
The car sounds AWESOME. Thanks to EPP for getting us the Procharger bits that we needed and quickly! Glad you got it back today Tim, happy birthday. Somebody get this man a TIRE!
Old 03-28-2009, 11:14 PM
  #57
AFASTYZFR1's Avatar
car is done and shop is cleaned up.........time to
Steve did an excellent job tuning this car
Tim is ready to
Old 03-29-2009, 07:31 AM
  #58
The coolest part about it is, I bought this car bone stock 2 years ago... I take that back, it had a Borla cat-back... Slowly it got a lid... lt's.... new cat-back...then I met Frost and he's pretty convincing when it comes to selling you on the idea of making the car fast... So the AFRs and FAST pieces went on, with the insane cam... A year later, here we are w/ one hella' big blower and (eventually) all the HP my dumbass will be able to handle.
Just been kinda' fun watching/feeling the car progress... and to think the original idea when the car was purchased was to have a nice, stock vehicle. ...Kinda' f'd that one up, huh?
By the way... Do I finally earn a spot on your "Customer Rides" section Steve? lol
Old 03-29-2009, 09:10 AM
  #59
LS1Tech Sponsor
Superman09's Avatar
ummmmm, vids? I am very anxious to hear the F1!
BTW, looks to be a VERY amazing neighborhood!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 03-29-2009, 09:19 AM
  #60
AFASTYZFR1's Avatar
It is loud.......was raining yesterday so we just got car tuned in time.....I'm sure Tim will get some vids soon..
Thanks
Quick Reply: Camaro SS F1-C Build
