HELP!!!!
Put car on lift and removed hose into the intercooler and promptly coated myself with about 1/2 pint of oil.. NOT GOOD.
Is there a gasket leak in one of the Turbos?? Car runs great and showed not smoke out of exhaust butthat amount of oil if ANY cannot be good.
Any information will be appreciated.
Gary
Thanks for information...
This is not to say you don't have a seal or oil volume problem. Is your setup one of the early ones that was sent out, if so Incon had to add a additional inline orifice in the oil inlet fitting to prevent over oiling. In the later setup Garrett supposidly added an a smaller orifice in the CHRA housing and Incon did not supply a inline orifice. I have the same oiling and my turbo is fine, plus I did not even get my turbos from Incon.
Gary
