Best (low compression) ATI Blower Cam?
Right now I'm running a Cam that's 224/227 .563/.569 114 LSA. Although I love the lope, I think I'm losing pressure through the overlap.
Anyone running a blower cam they're happy with?
In the future I will most likely step up to a 224/226 .590/.600 117lsa
I think I'm gonna install my MMS blower cam first on my current setup and see if I like it. If I don't I'll call Comp Cams and have a customer blower cam made. I called them a few months ago and told them I wanted a 218/224 cam and they recommended to me a 218/224 .563/.568 115lsa cam. Plus it's got some killer lobes. If I don't like the stage 1 MMS blower cam I'll call Comp.
Packy, where does the P1SC blower start to make boost? Thanks.
Den
It now has a forged LS6 bottom and stage 2 LS1 heads (A&A Stage 2 CNC blower heads). I had hopes for high boost with an 8.8:1CR. With 3.5" pulley and MMS bracket I have 8psi and slippage. Hopefully all those mods would add 150 or so rwhp, but so far it doesn't feel like it.
Here's an excerpt from a recent Modular Power magazine article (a mustang magazine), where they interviewed Vortech's founder and president Jim Middlebrook, regarding the engine oil-tap:
MP: Vortech superchargers utilize engine oil for lubrication, as opposed to self-contained supercharger lubrication. You obviously feel that engine oil is superior for supercharger lubrication.
Middlebrook: Yes, because engine oil provides faster warm-up and superior cooling to other types and is virtually maintenance free. In the self-contained units, nearly all the heat generated by the drive system and compressor to go into the charge air. The self-contained units can run very hot under high boost conditions when they are working hardest. In my view, only the superchargers attached to the engine’s lubricating and cooling system address these issues.
Den
The MMS bracket looks like this (it has belt debris on it from slippage): MMS pulley with belt slip debris
Here's another pic from the rear, I drilled across the pulley to stop belt slippage:
Drilled pulley & bracket
Has any ATI people noticed high intake temps due to the fact it's self contained?
Packy, Wow thats good to hear that the P1SC unit makes boost early. I was alittle concerned that there was too much lag. I've thought about replaced the whole twin intercooler setup and run a single 2 or 3 core intercooler with a HKS adjustable BOV.
Den
Den
