3.08 or 3.50's?
Old Mar 17, 2009 | 03:38 PM
69TA's Avatar
Default 3.08 or 3.50's?
Have 3.50's now and thinking about going to 3.08's.
Do you guys think this is a better gear or should I stay with the 3.50's
Anyone with some experience with either gears
please let me know what you think?
car is a full weight TA running twin APS on a stock bottom end
4l80e trans
Moser 9"
26" tall 315 street tires
Old Mar 17, 2009 | 03:59 PM
SuperZ's Avatar
You could do 3.25s.Ive got 3.25s with a 28 tire and it works well.I may go down still.
Old Mar 17, 2009 | 04:00 PM
30th t/a's Avatar
alot of people like their airplane gears but I have 3:42s now and im really considering of swapping in 3:73s, just to make it more fun to drive around below 3000. Ill still be good for 135 traps. So of course my vote is keep the 3:50s.
Old Mar 17, 2009 | 05:55 PM
ninetres's Avatar
I'd like to switch my 3.25s out for 3.50s if that helps you decide. I run a 28" slick, TH400, and shift at 6500ish. I also drive on the street ALL THE TIME. Never been afraid of a few thousnd RPMS here and there
Old Mar 17, 2009 | 06:00 PM
PowerShift408's Avatar
I'd vote to keep the 3.50s. What is the reason your wanting to go to the 3.08s?
Old Mar 17, 2009 | 06:24 PM
MY99TAWS6's Avatar
I am going with 3.54 in dana 60. Thats lowest you can go in dana 60. Might need to wind it up to 6500 maybe 7000 on the odd track run. Not overly worried about it.
Likely will be running 26 inch tires.
We hear how 3.08 help it spool faster by giving it more more load. I know mine with the 408 spools stupid fast now so really don't need faster spool up. I also street drive my car a lot and really don't like 3.08 in town and off boost and you won't be in boost much in town. Unless you like to lose your liscence. At least in my town. Heck my 408 has lots of grunt down low anyway even off boost and even with 9.5 to 1. Also off course with auto and stall you shouldn't have too much trouble spoolin up the turbo compared to say an m6 off the line.
Also in the old boosted lists which are still there if you search but for some reason not stickied anymore there are mnay cars running very fast with 3.73 and even 4.10 gears.
Fact JM did high 9s at near 140 in his 4l80e APS car with 4.10 gears. 4l80e trans and PY3400e stall. Gears don't seem to have hurt him any..But of course you would gear lower to get more mph if you needed it. So maybe these 3.08 guys are trying for 160mph in the 1/4 or something..? As for helping out in the traction department 3.08 might help some in that area but as said I don't like having any gear under 3.42 off boost around town.
Old Mar 17, 2009 | 07:25 PM
69TA's Avatar
Only reason I am wanting to do the 3.08's is to try to see if I
can get a better quarter mile time.
Old Mar 17, 2009 | 09:52 PM
69TA's Avatar
what rear gear are you running on your set up?
Old Mar 18, 2009 | 07:56 AM
ibepressin's Avatar
I think the one thing missing from this discussion is weather you are running a stick or auto with whatever said gears. An auto wont be as critical to have higher gears "numerically lower" as it loads the turbo just one time then stays spooled.
Old Mar 18, 2009 | 08:14 PM
69TA's Avatar
Yeah it's an auto and the 4l80e has steeper first gear than a 4l60e that's what made me think about going with 3.08's
Old Mar 19, 2009 | 06:09 AM
ibepressin's Avatar
Auto would be a matter of when do you run out of gear (1/4 mile) or how high do you want to rev your car on the highway. For me (performance minded) I'd go as low as I could and still consider it drivable. Maybe 373's?
