To hell with n/a!!!!!!!!!!
Old Mar 17, 2009 | 07:01 PM
IT_SS's Avatar
Default To hell with n/a!!!!!!!!!!
I'm thinking about slapping a pair of twins on my LS1 Camaro personally, I've been doin some research and it looks my lil ole LS1 can handle up to 13 PS1 with the stock 10.1-5:1 compression ratio (i have now intention on boosting that hi). I just wanted a little input and insight on what should be done as far as engine mods. I know the crank can take it, but rest of the rotating assembly (rods, pistons) need to be swapped for forged materials, in which case, low compression pistons can cam in to play. And i also want the idle to sound as stock as possible, and stock head. So point me in the right direction.
Old Mar 17, 2009 | 08:17 PM
OUTLAWZ RACING's Avatar
317 truck heads 04 z06 cam ls6 intake stock t body will be a nice set up.
Old Mar 17, 2009 | 09:05 PM
IT_SS's Avatar
Would the FAST 92/92 help any?
Old Mar 18, 2009 | 12:10 AM
99Z28LS1's Avatar
there arent many that run that set up in the boosted side. thats a great combo for a N/A set up.
most in here that get an aftermarket intake usually get the Victor Jr intake with an elbow
but this is just based on what i've seen in here many times
Old Mar 18, 2009 | 06:04 AM
30th t/a's Avatar
Sounds like my setup
im in the process of bumping my CR from 8.6:1 to 10:1.
Old Mar 18, 2009 | 06:55 AM
Photochop's Avatar
Sell it, buy an LS6 intake used. Use that extra money you make on larger injectors.
On my build, it was a h/c forged bottom end car when I bought it. I was able to sell the old ported heads, cam, injectors, fast 90, and long tubes to fund the stock 317 heads (overhaul, valve job, minor decking), injectors, and LS6 manifold among other things. Sell/buy man!
Old Mar 18, 2009 | 01:15 PM
IT_SS's Avatar
I have an 02, so if I'm correct, I have an LS6 intake already.....should i leave it as is? or port it? and what about porting stock heads?
Old Mar 18, 2009 | 01:59 PM
Pat-Man's Avatar
You have a LS6 intake already (no EGR provisions). You definitely want to get some 60# injectors. How much boost and HP are you looking at?
Old Mar 18, 2009 | 09:06 PM
IT_SS's Avatar
i know 500RWHP @ about 8PSI is more than possible, but i want to make sure that (shall i feel stupid one day) it can handle more @ the crank...
Old Mar 18, 2009 | 09:14 PM
IT_SS's Avatar
and should i also ditch the stock heads? or port them? I want my engine bay to look stock...
Old Mar 18, 2009 | 09:21 PM
Rickys S/C Z28's Avatar
you want it to look stock with twins?? are you going to be doing some sort of twine rear mount set up?? and on 8 psi my car only made like 480
Old Mar 18, 2009 | 10:07 PM
IT_SS's Avatar
Well, im saving up for the APS kit.
And also, 480 is about right for an A4, im no expert so i really cant say...
Old Mar 19, 2009 | 12:51 AM
trnsfmr99's Avatar
LOL!!! I hear that and feel that!!! I don't know about the twins, but my turbo kit's in the process of being built by Josh at Kentucky Turbo. I have a 99 SS with worked LS-1 heads. A little more work has been done to the internals (stock nodular) parts, and the crank is stock too. This will be my first turbo kit ever. I was spraying a TNT wet kit 150 hp shot, without retarding the timing and it held up beautifully. I'm really exited to see what this turbo kit's gonna do (76mm) with this practically stock setup. I'd love to do about 10 to 12 psi, but no more. Good luck with your hunting. Hope the twins work out for you.
Old Mar 19, 2009 | 12:19 PM
IT_SS's Avatar
Thanx, I think I've got a pretty good idea of what needs to be done. I'm not trynna be the fastesr, I'm just the only one of my buddies that didn't get a TT Import. It pains me to be spanked by a boosted Nissan, Toyota and Dodge/Mitsubishi.....so I'm going to show these ******** what boost can do in an LS!1
Old Mar 19, 2009 | 06:16 PM
IT_SS's Avatar
what truck do the 317 heads come on?
Old Mar 20, 2009 | 08:39 AM
Should be killer, Thats my budget build for my cousins c-10
