Crankcase problems, blowing out dipstick
This is what I have currently for crankcase evac
-10 line from the lifter valley to an air/oil seperator to the suckside of the Blower.
I did have a checkvalve installed and when I took the checkvalve out it seemed to help since I started to see build up in the air/oil seperator. It still blowing the dipstick, just not nearly as bad.
What should I do, to help with the crankcase pressure???
Thanks, Ben
The motor is brand new less than 45 minutes run time, surely nothing is messed up.
98Camarod did you have yours setup like mine initially too?
If your using the blower to pull crank case pressure and the dip stick is still comming out you might have other issues.
I just don't want to have any oil smells or oil pucking on the valvecovers.
Do you guys use any type of screens for those applications?
Any more ideas?
You also need a good filtered fresh make-up air source (the stock setup would pull from the front of the TB through the pass valve cover front vent) so a good filtered breather works well.
If you still have issues after setting up the proper system, then as mentioned above you have internal issues. Most likely piston/ring/cyl bore problems allowing excess blow-by.
Any more ideas?
Then again this is my daily driver. I always change my oil though by 3,000 miles though.
You would need to change your oil after every few outings...2-3k miles would still allow damage. Every time the motor reaches operating temp the water & impurities (sulferic acid is just one combustion byproduct) flash-off and become gasses....and if not flushed with a proper evac system (even a simple drag car will have evac valves in the header collectors to pull them out to prevent damage, and most of them change oil every few races as well) these will re-condense when your motor cools down coating any bare metal parts & start to corrode them, and your oil gets it dripped back down into it as well.
On our race motors we run belt drive vac pumps (Moroso or Aeropace technologies are my choice) with a vac relief valve in the opposite valve cover than we pull from. This is them routed to a breathered plain catch can for drainage later. But this setup is not practical for most.
Please understand that I'm not just a weekend motorhead with an opinion based upon what I THINK is true, but an engine builder for the past 40 years and former owner of a pro Alky race team that for years was one of the winningest in the big $ bracket circle, as well as a grad of Reher Morrison race engine building school. This is my life, not a hobby. Just trying to share knowledge (not opinions) of facts...many learned the hard way from expensive damage done in the past.
I wasn't trying to step on any toes, just letting him know how I fixed the similar problem. I don't really see how what I said is an opinion, the fact is that my blow by is non existent now with the cans. My oil is clean, even with over 80k miles on it.
I have done searching on three different forums and I have heard several ideas and theories on the subjuct?
I went w/ the Morosso crank case evac kit. Initially I had 4 breathers, then I switched to 2 catch cans--1 per VC along w/ a high grade oil water seperator for the PCV. I still use the oil water seperator now but ditched all those other variations for the crank case kit. My dipstick is welded shut so I don't know about those kinds of things but what I have works. I change my oil every 1500 to 2000 miles and sometimes every 500 miles since it's a weekend toy and nothing else. Don't even see track time in it no more as all they have are 1/8th tracks around these parts.
You may have other issues but I sincerly hope that isn't the case as you've been working on this for a LONG time and that would suck the big one not seeing your hard work pay off for you.
Silas,
