How much boost will this be.
Old Apr 23, 2009 | 08:24 AM
josepy121380's Avatar
Default How much boost will this be.
My setup
Stock Block, Heads, intake, cubes.
3 bar map, Epp Blower cam. Hardened pushrids and double valve springs. EPP K&N Blower filter, 60lb injectors. Lt's ,ory and hooker exhuast. 3.73 gears through 12 bolt. Rod Bols, Slp Oil Pump, DLubel roller chain. To many parts to list.
P1sc-1 procharger 3.5 intercoolers
I have the 8 rib setup with 4.00 pulley and 3.85. I am looking for 8-10lbs boost. Which pulley will do that with my setup?
Old Apr 23, 2009 | 09:43 PM
really no answers
Old Apr 23, 2009 | 09:47 PM
InsaneDomestics's Avatar
Try Contacting Procharger...
Old Apr 23, 2009 | 10:26 PM
I did. The guy didn't give me a real good feeling about what he said. Almost seemed unsure.
Old Apr 24, 2009 | 08:56 AM
slow67's Avatar
Gingervitis Addict
Call EPP
Old Apr 25, 2009 | 05:34 PM
Originally Posted by slow67
Call EPP
yeah im going to have too. i thought someone on here would know.
Old Apr 27, 2009 | 05:27 AM
WS6Drop's Avatar
If you figure it out, let me know too. Our setups are similar and I am asking the same question. Hard to believe nobody has an idea.
Old Apr 27, 2009 | 11:58 AM
I just called Procharger, they say 8psi.
Old Apr 27, 2009 | 12:01 PM
Aster's Avatar
8 to 9 sounds about right. When I was on the stock short block with the 7.625 crank pulley and 3.85 head unit pulley I was getting around 9psi on the P1SC. the P1SC-1 may be a little different, but probably not much.
Old Apr 28, 2009 | 08:15 AM
Thanks I will have vids up when its done.
Old Apr 29, 2009 | 11:59 PM
WS6Drop's Avatar
Thanks for the info. Looking forward to your vid.
Old May 1, 2009 | 04:22 AM
EPP's Avatar
EPP
Definitely go with the 3.85 pulley. Bob
Old May 1, 2009 | 08:50 AM
Really? Procharger told me the 4.00 would get me there. What to do what to do.
Even on the 8 rib setup go with the 3.85. I hope it doesn't shoot me past 10lbs.
Old May 1, 2009 | 11:01 AM
Aster's Avatar
The 4" won't get you there. You are pushing through the 3.5" intercoolers which become a restriction in the upper RPM band. Like Bob said above start with the 3.85 that should put you right in the middle of your goal for 8 - 10psi.
Old May 1, 2009 | 12:04 PM
thanks a lot guys.
