what line for e85 on 408?
what line can i use for gas and return.Thanks.
I agree that the a1000 won't keep up, maybe get another one, and it might work.
Link I sent the OP. https://ls1tech.com/forums/forced-in...05hp-corn.html
"Car is on a stock PCM with the AEM driver box and has precision 96lb injectors with a BFP of 60psi"
seriously 60psi at base fuel pressure. you add 18 lbs of boost and you are up to 78psi. is that safe? i would have just used 120 and call it a day.
His post.
Bumping the BFP from 43psi to 60psi helped the injector DC out a lot, but actually made the car lean out up top. The pumps just couldn't flow the volume as when at 43psi. AFR has been rock solid with the lower FP and higher injector DC.
17-18psi has it maxed on E85. Have had her to 22-24psi on gas though.
