Good Place to Buy Turbo kit parts
turbo kit advice/parts ??
Well I've decided that i want to build my own single turbo kit
I'm looking for place that will be able to help me with parts list for a single turbo kit on my Gmc sierra
Are there any books to read on turbo applications
I need to figure out what size unit would be right for my application
the Engine is a built 6.0l Bored .30 over with a 9:1 Compression
I have stage 2 Absolute 6.0l heads with2.02 intake and 1.6ex valves
What other specs will i need to know to properly size the turbo unit
The truck made 534rwhp and 500rwtq on the dyno recently
Any help would be much appreciated
I'm just at my wits end with ATI procharger belt slip issues Nobody makes a turbo kit yet for the trucks so i figure I make my own
GURU's Help me out
Jim
GURU's Help me out
Jim
Turbo Addict
go through these guys :
http://www.proturbokits.com/index.htm
click on "parts and components" at the top.
Talk to Greg if you call..... they will have everything you need probably in stock... if not then they can make/get it in 1-2 days. They do great work.
Hope this helps.
-Jarrod
Hope this helps.
-Jarrod
Nothing less than a t76 you think it ,will spool nice and quick?
When will it start to make boost and when will it make full boost by ?
I wanna size this thing perfect for what i have
this time I'm doing it once
Adkoonerstrator
As far as spool time I don't know never owning a turbo vehicle but, with your stall converter I don't think spool time will be an issue. I really don't think it would be an issue without the stall but, with it you better be holding on the wheel when you hit the gas.
The T76 compressor map really fits a motor your size very nicely. Anything smaller and you'll just have to spin it harder and further out of it's efficiency range to make the same power.
Somebody with a T76 on a Fbody needs to chime in on how it spools up.
