Lets try this again. What cam should I use?
Old May 2, 2009 | 06:54 PM
jasonpickett's Avatar
Default Lets try this again. What cam should I use?
This is what I am building:
6.0l diamond pistons std. bore callies or eagle rods std. stroke.
317 heads-ported/polished for now. Will do bigger valves later.
Precision PT88- 88mm compressor wheel, 94mm turbine wheel with .96A/R
4l80e trans. 3500 stahl. Probally will use lockup if that matters.
AWD 3.42 gears.
I need to know what would be the best cam for the setup. I want it aggressive(lumpy). Please help. Also what would be some good rockers for this.
If you need any other information. Please let me know. Oh yeah HP range hopefully 1000-1200.
Thanks,
Jason
Old May 2, 2009 | 07:09 PM
THe first time I tried it I was all over the place. 4 different turbos. I now realized what I wanted to use.
Old May 3, 2009 | 05:18 PM
Up ttt
Old May 3, 2009 | 06:25 PM
stevieturbo's Avatar
https://ls1tech.com/forums/search.php
For a topic that has been done to death, and there are literally dozens...if not more camshafts that would fulfill your requirements.
You may want to consider cylinder head/head gasket sealing first though.
Old May 5, 2009 | 11:42 AM
anybody
Old May 5, 2009 | 11:47 AM
Fireball's Avatar
Call one (or more) of our supporting sponsors that specialize in Turbos. They will get you a cam matched to your combo...
I personally deal with Shawn @ Va Speed
98Z28CobraKiller's Avatar
Restricted User
Comp has FI cams on the shelf. Call them. I intend to forge my bottom end and throw on some AFR heads. At that time, I intend to use something in the 230/230 59x/59x 115 LSA or there abouts. The 317 heads seem to respond well to LS6 and LS7 stock cam profiles from what I have seen.
Old May 6, 2009 | 05:11 AM
EPP's Avatar
EPP
http://www.exoticperformanceplus.com....html?item=679
Our blower cam will do a really good job for you, plus it has a great sounding idle.
http://www.google.com/url?sa=t&sourc...qxTpziBgxfNbTA
http://www.google.com/url?sa=t&sourc...5YWUFiHAvm-0zA
http://www.google.com/url?sa=t&sourc...xCCHKyqFWRMl6g
Bob
Old May 6, 2009 | 05:14 AM
White.Lightning's Avatar
Call a sponsor like Brian said and have them spec you a cam for your combo.
Old May 6, 2009 | 09:27 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Best is your best solution....
