low compression no FI ???
Old May 8, 2009 | 09:23 PM
DCsLS1's Avatar
Default low compression no FI ???
figured id post this here since people in this section might have some experience in this situation. Ok heres the deal i have the epps FI cam (232-240 115lsa) and lq9 stage III heads 72cc combustion chambers that are about ready to be installed as i plan on doing procharger later on once i can save up enough, my question is i know this is going to lower my compression so am i going to gain power at all with this h/c set up vs stock or am i going to loose power since it will lower my cr? seeing as it might be a little while till i can save up for the procharger i would like to know if im going to gain anything from this or loose anything. thank you for any input.
Old May 8, 2009 | 10:31 PM
elias_799's Avatar
you will loose power because you lowered your CR, but you should be able to gain some with the new heads. but i think it will work out that you loose a little bit of power. if you have an ls1 your cr will be around 9.5:1 instead of 10.25:1 with the 72 cc heads.
Old May 9, 2009 | 12:43 AM
Jimmy P's Avatar
I would guess that you would loose a bit of low end torque, but gain hp on top.
Old May 9, 2009 | 08:25 AM
DCsLS1's Avatar
yea its an ls1 damn thats a big drop but i guess it will be perfect for when the procharger goes on
Old May 9, 2009 | 08:26 AM
DCsLS1's Avatar
i hope i gain something because it might be a little while before i can afford the pc and i dont want to have less power until then lol
Old May 9, 2009 | 12:25 PM
DCsLS1's Avatar
no one else has been in this situation??
Old May 9, 2009 | 12:35 PM
TripleWhite96's Avatar
why not just wait to put them on with the procharger?
Old May 9, 2009 | 12:55 PM
DCsLS1's Avatar
i thought about it but i dont know how long i can let heads and cam just sit there before im like ok **** this there going on lol plus if it is going to gain something then its worth it
Old May 9, 2009 | 02:45 PM
calongo_SS's Avatar
You should pick up a nice bit of hp up top vs. stock heads and cam even with the drop in compression.
